Ana içeriğe geç
Ematic Genesis Camera Replacement
Neye ihtiyacın var
  1. Ematic Genesis Camera Replacement, Ematic Genesis Casing: adım 1, 3 resimden 1. Ematic Genesis Camera Replacement, Ematic Genesis Casing: adım 1, 3 resimden 2. Ematic Genesis Camera Replacement, Ematic Genesis Casing: adım 1, 3 resimden 3.
    • Unscrew the two (2) 1.3mm Phillips #00 screws found on the bottom edge of the tablet, where the power and volume buttons are located.
  2. Ematic Genesis Camera Replacement: adım 2, 3 resimden 1. Ematic Genesis Camera Replacement: adım 2, 3 resimden 2. Ematic Genesis Camera Replacement: adım 2, 3 resimden 3.
    • Insert plastic opening tool into the edge between the screen plate and the back plate to create a separation between the casings.
    • Insert the flat end of the spudger next to the plastic opening tool and carefully pry the edges apart. Continue this all around the edges until the casings separate.
    • There may be cracking sounds when prying them apart. If carefully done, this is only the locks coming apart and is not harmful.
    • Be careful when separating the two plates as they are connected by the speaker wires and could be disconnected during this process.
  3. Ematic Genesis Camera Replacement: adım 3, 1 resimden 1.
    • Remove back plate from screen plate and lay both down flat next to each other.
  4. Ematic Genesis Camera Replacement, Camera: adım 4, 2 resimden 1. Ematic Genesis Camera Replacement, Camera: adım 4, 2 resimden 2.
    • Once the panels are separated, remove the tape holding down the ribbon connector that is connecting the camera to the motherboard.
  5. Ematic Genesis Camera Replacement: adım 5, 2 resimden 1. Ematic Genesis Camera Replacement: adım 5, 2 resimden 2.
    • Lift up the black lever of the connector that holds the camera ribbon in place.
  6. Ematic Genesis Camera Replacement: adım 6, 2 resimden 1. Ematic Genesis Camera Replacement: adım 6, 2 resimden 2.
    • Gently pull the ribbon out of the connector and lift the camera out of the casing.
    • There is adhesive holding the camera in the case. Pull up strong enough to separate the camera from the casing without damaging the components.
Sonuç
Justin Rohrman
745 İtibar
6 adet Kılavuz yazıldı
Ekip
Baylor, Team 4-3, Williams Spring 2015 Baylor, Team 4-3, Williams Spring 2015 üyesi
BU-WILLIAMS-S15S4G3
3 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 34
Her zaman: 327
