Ana içeriğe geç
Ematic Genesis Speaker Replacement
Neye ihtiyacın var
  1. Ematic Genesis Speaker Replacement, Ematic Genesis Casing: adım 1, 3 resimden 1. Ematic Genesis Speaker Replacement, Ematic Genesis Casing: adım 1, 3 resimden 2. Ematic Genesis Speaker Replacement, Ematic Genesis Casing: adım 1, 3 resimden 3.
    • Unscrew the two (2) 1.3mm Phillips #00 screws found on the bottom edge of the tablet, where the power and volume buttons are located.
    FixBot'a Sor
    Yorum Ekle
  2. Ematic Genesis Speaker Replacement: adım 2, 3 resimden 1. Ematic Genesis Speaker Replacement: adım 2, 3 resimden 2. Ematic Genesis Speaker Replacement: adım 2, 3 resimden 3.
    • Insert plastic opening tool into the edge between the screen plate and the back plate to create a separation between the casings.
    • Insert the flat end of the spudger next to the plastic opening tool and carefully pry the edges apart. Continue this all around the edges until the casings separate.
    • There may be cracking sounds when prying them apart. If carefully done, this is only the locks coming apart and is not harmful.
    • Be careful when separating the two plates as they are connected by the speaker wires and could be disconnected during this process.
    FixBot'a Sor
    Yorum Ekle
  3. Ematic Genesis Speaker Replacement: adım 3, 1 resimden 1.
    • Remove back plate from screen plate and lay both down flat next to each other.
    FixBot'a Sor
    Yorum Ekle
  4. Ematic Genesis Speaker Replacement, Speaker: adım 4, 1 resimden 1.
    • Once panels are separated, disconnect speaker wires from motherboard.
    • Make sure device is completely turned off before doing this to avoid a potential electric shock.
    FixBot'a Sor
    Yorum Ekle
  5. Ematic Genesis Speaker Replacement: adım 5, 2 resimden 1. Ematic Genesis Speaker Replacement: adım 5, 2 resimden 2.
    • Insert the flat end of the spudger between the casing and the speaker. Push inwards to pry the speaker from the casing.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Justin Rohrman
745 İtibar
6 adet Kılavuz yazıldı
Ekip
Baylor, Team 4-3, Williams Spring 2015 Baylor, Team 4-3, Williams Spring 2015 üyesi
BU-WILLIAMS-S15S4G3
3 Üyeler
12 adet Kılavuz yazıldı
1Rehber Yorum
This help us alot, thanks for posting troubleshooting
wikirichard - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 20
Her zaman: 450
