Ana içeriğe geç
Ematic Model FTABMP2 Battery Replacement
Neye ihtiyacın var
    1. Ematic Model FTABMP2 Battery Replacement, Battery: adım 1, 2 resimden 1. Ematic Model FTABMP2 Battery Replacement, Battery: adım 1, 2 resimden 2.
      • Use a spudger to pry open the case. Do this on the long side of the case. This will reveal the inside.
      FixBot'a Sor
      Yorum Ekle
    2. Ematic Model FTABMP2 Battery Replacement: adım 2, 2 resimden 1. Ematic Model FTABMP2 Battery Replacement: adım 2, 2 resimden 2.
      • Disconnect the LCD cable from the motherboard by pressing together the two sides of the clamp to separate the device into two.
      FixBot'a Sor
      Yorum Ekle
    3. Ematic Model FTABMP2 Battery Replacement: adım 3, 2 resimden 1. Ematic Model FTABMP2 Battery Replacement: adım 3, 2 resimden 2.
      • First, Remove the screws holding down the motherboard. Then remove the plastic power and volume buttons.
      • Next, remove the two side grips of the device. Now, you can remove the motherboard, speaker, and battery as one from the device.
      FixBot'a Sor
      Yorum Ekle
    4. Ematic Model FTABMP2 Battery Replacement: adım 4, 1 resimden 1.
      • Unsolder the gray, black, and red wires from the motherboard to release the battery.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Timothy
505 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 9-2, Brown Winter 2015 USF Tampa, Team 9-2, Brown Winter 2015 üyesi
USFT-BROWN-W15S9G2
5 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 25
Her zaman: 428
