Ana içeriğe geç
Ematic Model FTABMP2 Case Replacement
Neye ihtiyacın var
  1. Ematic Model FTABMP2 Case Replacement, Case: adım 1, 2 resimden 1. Ematic Model FTABMP2 Case Replacement, Case: adım 1, 2 resimden 2.
    • Use a spudger to pry open the case of your device to reveal the inside.
  2. Ematic Model FTABMP2 Case Replacement: adım 2, 2 resimden 1. Ematic Model FTABMP2 Case Replacement: adım 2, 2 resimden 2.
    • Disconnect the LCD cable from the motherboard by pressing together the two sides of the clamp to separate the device into two.
  3. Ematic Model FTABMP2 Case Replacement: adım 3, 1 resimden 1.
    • Use the spudger to pry the LCD from the clamps holding it to the case.
  4. Ematic Model FTABMP2 Case Replacement: adım 4, 2 resimden 1. Ematic Model FTABMP2 Case Replacement: adım 4, 2 resimden 2.
    • If you need to remove the back part of the casing, after disconnecting the LCD display from the motherboard, remove the screws holding down the motherboard. Remove the plastic power and volume buttons. remove the two side grips of the device.
  5. Ematic Model FTABMP2 Case Replacement: adım 5, 2 resimden 1. Ematic Model FTABMP2 Case Replacement: adım 5, 2 resimden 2.
    • Remove the motherboard, speaker, and battery as a whole, which leaves just the back casing of the device.
Sonuç
Timothy
505 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 9-2, Brown Winter 2015 USF Tampa, Team 9-2, Brown Winter 2015 üyesi
USFT-BROWN-W15S9G2
5 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 147
