Ana içeriğe geç
Ematic Model FTABMP2 Case Replacement
Neye ihtiyacın var
  1. Ematic Model FTABMP2 Case Replacement, Case: adım 1, 2 resimden 1. Ematic Model FTABMP2 Case Replacement, Case: adım 1, 2 resimden 2.
    • Use a spudger to open your device's case, revealing the inside.
    FixBot'a Sor
    Yorum Ekle
  2. Ematic Model FTABMP2 Case Replacement: adım 2, 2 resimden 1. Ematic Model FTABMP2 Case Replacement: adım 2, 2 resimden 2.
    • Disconnect the LCD cable from the motherboard by pressing the two sides of the clamp together.
    FixBot'a Sor
    Yorum Ekle
  3. Ematic Model FTABMP2 Case Replacement: adım 3, 1 resimden 1.
    • Use the spudger to pry the LCD from the clamps that hold it in the case.
    FixBot'a Sor
    Yorum Ekle
  4. Ematic Model FTABMP2 Case Replacement: adım 4, 2 resimden 1. Ematic Model FTABMP2 Case Replacement: adım 4, 2 resimden 2.
    • If you need to remove the back part of the casing:
    • After disconnecting the LCD from the motherboard, remove the screws that hold down the motherboard.
    • Remove the plastic power and volume buttons.
    • Remove the two side grips of the device.
    FixBot'a Sor
    Yorum Ekle
  5. Ematic Model FTABMP2 Case Replacement: adım 5, 2 resimden 1. Ematic Model FTABMP2 Case Replacement: adım 5, 2 resimden 2.
    • Remove the motherboard, the speaker, and the battery, leaving just the back casing of the device.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Timothy
505 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 9-2, Brown Winter 2015 USF Tampa, Team 9-2, Brown Winter 2015 üyesi
USFT-BROWN-W15S9G2
5 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 23
Her zaman: 367
