Giriş
This guide will help you remove the rear panel of your Emetic eGlide 4 to access the internal parts by instructing you where to find anchoring screws and how to remove them. There is a screw on the bottom of the device that holds the front screen and rear panel together. Once the screw is removed it releases the rear panel away from the device, making internal part visible.
Neye ihtiyacın var
Bir başkası bu kılavuzu tamamladı.
