Ana içeriğe geç
Ematic eGlide 4 Side Button Array Replacement
Neye ihtiyacın var
  1. Ematic eGlide 4 Side Button Array Replacement, Rear Panel: adım 1, 1 resimden 1.
    • Remove the 4.6mm Phillips #00 screw at the base of the device.
    FixBot'a Sor
    Yorum Ekle
  2. Ematic eGlide 4 Side Button Array Replacement: adım 2, 1 resimden 1.
    • Slide the rear panel away from the base parallel to the screen.
    FixBot'a Sor
    Yorum Ekle
  3. Ematic eGlide 4 Side Button Array Replacement: adım 3, 2 resimden 1. Ematic eGlide 4 Side Button Array Replacement: adım 3, 2 resimden 2.
    • Carefully remove the speakers from the rear panel.
    • Pull the speakers off of the rear panel.
    FixBot'a Sor
    Yorum Ekle
  4. Ematic eGlide 4 Side Button Array Replacement, Side Button Array: adım 4, 1 resimden 1.
    • Remove the 3 Phillips #00 4.5 mm screws from the side button array.
    FixBot'a Sor
    Yorum Ekle
  5. Ematic eGlide 4 Side Button Array Replacement: adım 5, 2 resimden 1. Ematic eGlide 4 Side Button Array Replacement: adım 5, 2 resimden 2.
    • Slide the grey ribbon wire connector clip away from the ribbon wire port on the motherboard using the pointed tip of a spudger. This process will unclip the wire from the motherboard to release connection.
    • You do not need to fully disconnect the ribbon wire clip from the ribbon wire port: the clip will stay attached in a loose fit.
    • Remove the ribbon wire from the ribbon wire port on the motherboard.
    FixBot'a Sor
    Yorum Ekle
  6. Ematic eGlide 4 Side Button Array Replacement: adım 6, 1 resimden 1.
    • Remove the side button array from the device.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bailey Hughes
617 İtibar
6 adet Kılavuz yazıldı
Ekip
Baylor, Team 5-8, Williams Spring 2015 Baylor, Team 5-8, Williams Spring 2015 üyesi
BU-WILLIAMS-S15S5G8
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 10
Her zaman: 285
