Ana içeriğe geç
Emson Star Wars R2-D2 Humidifier Fan Replacement
Neye ihtiyacın var
    1. Emson Star Wars R2-D2 Humidifier Fan Replacement, Fan: adım 1, 1 resimden 1.
      • Remove the top cover of the humidifier by pulling upwards.
      FixBot'a Sor
      Yorum Ekle
    2. Emson Star Wars R2-D2 Humidifier Fan Replacement: adım 2, 1 resimden 1.
      • Grip the dial from the front of the device and gently pull it away to remove it.
      FixBot'a Sor
      Yorum Ekle
    3. Emson Star Wars R2-D2 Humidifier Fan Replacement: adım 3, 1 resimden 1.
      • Remove the blue water tank of the humidifier by pulling upwards.
      FixBot'a Sor
      Yorum Ekle
    4. Emson Star Wars R2-D2 Humidifier Fan Replacement: adım 4, 2 resimden 1. Emson Star Wars R2-D2 Humidifier Fan Replacement: adım 4, 2 resimden 2.
      • Use a PH1 screwdriver bit and 150mm extension to unscrew the four screws from the bottom cover.
      FixBot'a Sor
      Yorum Ekle
    5. Emson Star Wars R2-D2 Humidifier Fan Replacement: adım 5, 1 resimden 1.
      • Remove the blue plastic top by pulling upwards on the middle notch.
      FixBot'a Sor
      Yorum Ekle
    6. Emson Star Wars R2-D2 Humidifier Fan Replacement: adım 6, 1 resimden 1.
      • This is where the fan is located. Carefully remove the fan from its compartment.
      • At this stage, you may remove the pin connector of the fan from the printed circuit board. However, it may be difficult to pull the pin. We recommend removing the printed circuit board for more clearance during removal.
      • Remove the screws on the printed circuit board using the same PH1 driver.
      FixBot'a Sor
      Yorum Ekle
    7. Emson Star Wars R2-D2 Humidifier Fan Replacement: adım 7, 2 resimden 1. Emson Star Wars R2-D2 Humidifier Fan Replacement: adım 7, 2 resimden 2.
      • Grip the fan's connector located on the printed circuit board and pull it away from the connector (see second picture).
      FixBot'a Sor
      Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Yash Chari
240 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 8-5, Eyestone Spring 2017 USF Tampa, Team 8-5, Eyestone Spring 2017 üyesi
USFT-EYESTONE-S17S8G5
4 Üyeler
25 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 28
Her zaman: 1,096
