Ana içeriğe geç
Enabot EBO SE Battery Replacement
Neye ihtiyacın var
    1. Enabot EBO SE Battery Replacement, Wheel Assembly: adım 1, 1 resimden 1.
      • Gently turn the robot upside down.
      • Place the robot on a stable surface to prevent it from rolling or falling.
      FixBot'a Sor
      Yorum Ekle
    2. Enabot EBO SE Battery Replacement: adım 2, 3 resimden 1. Enabot EBO SE Battery Replacement: adım 2, 3 resimden 2. Enabot EBO SE Battery Replacement: adım 2, 3 resimden 3.
      • Use a flathead 2.5 mm screwdriver to remove the 5.7 mm screw from the wheels.
      • A tool should have been provided in the box for this purpose.
      FixBot'a Sor
      Yorum Ekle
    3. Enabot EBO SE Battery Replacement: adım 3, 2 resimden 1. Enabot EBO SE Battery Replacement: adım 3, 2 resimden 2.
      • Pull the wheel assembly towards you so it comes straight off without resistance.
      • If there is resistance, make sure to apply gentle force when pulling as it can get damaged with too much force.
      FixBot'a Sor
      Yorum Ekle
    1. Enabot EBO SE Battery Replacement, Lower Housing: adım 4, 2 resimden 1. Enabot EBO SE Battery Replacement, Lower Housing: adım 4, 2 resimden 2.
      • Use a Torx screwdriver to remove the four 9 mm screws from the assembly.
      FixBot'a Sor
      Yorum Ekle
    2. Enabot EBO SE Battery Replacement: adım 5, 3 resimden 1. Enabot EBO SE Battery Replacement: adım 5, 3 resimden 2. Enabot EBO SE Battery Replacement: adım 5, 3 resimden 3.
      • Use your fingernail to carefully press down and eject the Micro SD Card from the back of the Enabot.
      • Keep the Micro SD Card in a safe spot for later.
      FixBot'a Sor
      Yorum Ekle
    3. Enabot EBO SE Battery Replacement: adım 6, 2 resimden 1. Enabot EBO SE Battery Replacement: adım 6, 2 resimden 2.
      • Place the iFixit opening tool inside the Micro SD slot.
      • Very carefully apply pressure to the top of the slot and pry open the casing to separate the upper and lower housing.
      FixBot'a Sor
      Yorum Ekle
    4. Enabot EBO SE Battery Replacement: adım 7, 3 resimden 1. Enabot EBO SE Battery Replacement: adım 7, 3 resimden 2. Enabot EBO SE Battery Replacement: adım 7, 3 resimden 3.
      • Using the iFixit opening tool or your fingernail, place it underneath the gray tab on the lower housing.
      • Lift the tab up and pull out the ribbon cable to disconnect it from the lower housing.
      FixBot'a Sor
      Yorum Ekle
    5. Enabot EBO SE Battery Replacement: adım 8, 3 resimden 1. Enabot EBO SE Battery Replacement: adım 8, 3 resimden 2. Enabot EBO SE Battery Replacement: adım 8, 3 resimden 3.
      • There are two black and red wire connectors attached to the upper and lower housing.
      • Gently use your finger nails to lift up and disconnect both wires to fully separate the upper and lower housings.
      FixBot'a Sor
      Yorum Ekle
    1. Enabot EBO SE Battery Replacement, Battery: adım 9, 3 resimden 1. Enabot EBO SE Battery Replacement, Battery: adım 9, 3 resimden 2. Enabot EBO SE Battery Replacement, Battery: adım 9, 3 resimden 3.
      • Use the iFixit opening tool or your fingernail to disconnect the cable by placing the edge underneath the gray tab.
      • Flip the tab up and pull the ribbon cable out.
      • Disconnect the red and blue wires from the daughterboard by using your finger nails to pull up on the connector to disconnect.
      FixBot'a Sor
      Yorum Ekle
    2. Enabot EBO SE Battery Replacement: adım 10, 3 resimden 1. Enabot EBO SE Battery Replacement: adım 10, 3 resimden 2. Enabot EBO SE Battery Replacement: adım 10, 3 resimden 3.
      • Use a Phillips #00 screwdriver to remove both 7.4 mm screws from the side of the battery's casing.
      FixBot'a Sor
      Yorum Ekle
    3. Enabot EBO SE Battery Replacement: adım 11, 2 resimden 1. Enabot EBO SE Battery Replacement: adım 11, 2 resimden 2.
      • Pull the battery casing upwards from the lower half of the assembly to remove it.
      FixBot'a Sor
      Yorum Ekle
    4. Enabot EBO SE Battery Replacement: adım 12, 2 resimden 1. Enabot EBO SE Battery Replacement: adım 12, 2 resimden 2.
      • Carefully remove the battery from the casing in order to replace.
      FixBot'a Sor
      Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Kevin H.
716 İtibar
5 adet Kılavuz yazıldı
8Kılavuz Yorumları
Una guía fantástica, pero no puedo seguirla porque no encuentro el recambio de la batería ¿Se puede usar una genérica? ¿Alguna referencia que me ayude a encontrar el recambio?
Rubén Belmonte - Yanıt Paylaş
tengo la misma duda, entendí perfecto el tutorial, que tipo de batería lleva?
Marina Daniela Regali - Yanıt Paylaş
What type of battery?
Commissioner Gordon - Yanıt Paylaş
18650 battery with ph2.0/2p connector
Camilo Jiménez - Yanıt Paylaş
Do you know what's the original battery capacity in mah?
wcy pierre - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 43
Son 30 gün: 221
Her zaman: 4,563
