Ana içeriğe geç
Ender 3 / CR20/PRO Y axis Linear rail kit install
Neye ihtiyacın var
  1. Ender 3 / CR20/PRO Y axis Linear rail kit install, Teardown: adım 1, 2 resimden 1. Ender 3 / CR20/PRO Y axis Linear rail kit install, Teardown: adım 1, 2 resimden 2.
    • Remove all 4 bed leveling screws for the Bed heater.
    • Lift the bed heater and set it behind or to the left of the printer
  2. Ender 3 / CR20/PRO Y axis Linear rail kit install, Teardown: adım 2, 3 resimden 1. Ender 3 / CR20/PRO Y axis Linear rail kit install, Teardown: adım 2, 3 resimden 2. Ender 3 / CR20/PRO Y axis Linear rail kit install, Teardown: adım 2, 3 resimden 3.
    • Remove all 4 idler pulley bracket screws
    • Lift pulley bracket to remove tension on the belt
    • Remove Y belt
    • Remove idler pulley bracket and set aside all parts
  3. Ender 3 / CR20/PRO Y axis Linear rail kit install, Y Carriage: adım 3, 3 resimden 1. Ender 3 / CR20/PRO Y axis Linear rail kit install, Y Carriage: adım 3, 3 resimden 2. Ender 3 / CR20/PRO Y axis Linear rail kit install, Y Carriage: adım 3, 3 resimden 3.
    • Slide off Y carriage of the front of the Y axis extrusion
    • Remove V-Slots wheels
  4. Ender 3 / CR20/PRO Y axis Linear rail kit install, Rail Prep: adım 4, 2 resimden 1. Ender 3 / CR20/PRO Y axis Linear rail kit install, Rail Prep: adım 4, 2 resimden 2.
    • Remove Linear Rails for packaging and Wipe off excess oil with a lint free cloth
    • Preinstall M3x8 SHCS and Sliding Tnuts
    • Take Note to skip 2 holes between each fastener, and ensure to mirror this process from each end of the rail until you overlap in the middle
  5. Ender 3 / CR20/PRO Y axis Linear rail kit install, Slide On & Mount Rails: adım 5, 3 resimden 1. Ender 3 / CR20/PRO Y axis Linear rail kit install, Slide On & Mount Rails: adım 5, 3 resimden 2. Ender 3 / CR20/PRO Y axis Linear rail kit install, Slide On & Mount Rails: adım 5, 3 resimden 3.
    • Note Sliding in the Linear rails do not allow rail block to slide off the end of the rails.
    • Insert Printed T-nut guide to help with sliding the rail into the top slot on the Y axis extrusion
    • Slide the rails into the top T-slot
    • Aline rails with the end of the extrusion using one of the included stiffener plates as a stop
  6. Ender 3 / CR20/PRO Y axis Linear rail kit install, Mount Rails: adım 6, 2 resimden 1. Ender 3 / CR20/PRO Y axis Linear rail kit install, Mount Rails: adım 6, 2 resimden 2.
    • Note when sliding on Rail alignment Jigs do not allow Linear rail block to slide off the end of the rails.
    • Tighten the M3 mounting bolts to the front of the rail to the back on both sides
  7. Ender 3 / CR20/PRO Y axis Linear rail kit install, Ender 3 / CR20-PRO 5th Hole: adım 7, 2 resimden 1. Ender 3 / CR20/PRO Y axis Linear rail kit install, Ender 3 / CR20-PRO 5th Hole: adım 7, 2 resimden 2.
    • Linear rail Block mounting hardware Per rail block mounting hole
    • M3x12 SHCS
    • M3 Flat Washer Per hole
    • Split lock washer
    • Stiffener plate 5th hole Screw (M3x10 SHCS with M3 washer)
    • M3 Hex nut
  8. Ender 3 / CR20/PRO Y axis Linear rail kit install, Mounting Rail Carriage Adaptors: adım 8, 2 resimden 1. Ender 3 / CR20/PRO Y axis Linear rail kit install, Mounting Rail Carriage Adaptors: adım 8, 2 resimden 2.
    • Right side
    • Left side
  9. Ender 3 / CR20/PRO Y axis Linear rail kit install, Y Carriage Install: adım 9, 3 resimden 1. Ender 3 / CR20/PRO Y axis Linear rail kit install, Y Carriage Install: adım 9, 3 resimden 2. Ender 3 / CR20/PRO Y axis Linear rail kit install, Y Carriage Install: adım 9, 3 resimden 3.
    • M4x10 FHCS
    • M4x12 BHCS
    • M4 washer
    • M4 washer large OD
    • M4 FHCS screw first. Then attach the M4x14S BHCS screw with the washer Stack.
    • Slide the Y Carriage forward and check that Y Carriage is parallel to that front of the Y extrusion. Then tight the screws fully.
  10. Ender 3 / CR20/PRO Y axis Linear rail kit install, Y Endstop Spacer: adım 10, 3 resimden 1. Ender 3 / CR20/PRO Y axis Linear rail kit install, Y Endstop Spacer: adım 10, 3 resimden 2. Ender 3 / CR20/PRO Y axis Linear rail kit install, Y Endstop Spacer: adım 10, 3 resimden 3.
    • Install this spacer between the Endstop bracket extrusion
    • Check that the y endstop is triggered by the Adaptor plate
  11. Ender 3 / CR20/PRO Y axis Linear rail kit install, Belt Re-install: adım 11, 3 resimden 1. Ender 3 / CR20/PRO Y axis Linear rail kit install, Belt Re-install: adım 11, 3 resimden 2. Ender 3 / CR20/PRO Y axis Linear rail kit install, Belt Re-install: adım 11, 3 resimden 3.
    • Re-install idler pulley bracket
    • Re-install Belt back into the tab slots
    • Pulley idler pulley bracket forward to tighten the belt.
    • Then tighten mounting screws on both sides
  12. Ender 3 / CR20/PRO Y axis Linear rail kit install, Reinstall Bed Plate: adım 12, 3 resimden 1. Ender 3 / CR20/PRO Y axis Linear rail kit install, Reinstall Bed Plate: adım 12, 3 resimden 2. Ender 3 / CR20/PRO Y axis Linear rail kit install, Reinstall Bed Plate: adım 12, 3 resimden 3.
    • CR20 Pro
    • Reinstall: bed heater plate, Solid bed mounts, Nylock nuts or bed leveling knobs
    • Ender 3 and CR20
    • Reinstall: bed heater plate, bed leveling springs and bed leveling knobs
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
AJ Pereira
2.707 İtibar
16 adet Kılavuz yazıldı
Ekip
Tiny Machines 3D Tiny Machines 3D üyesi
Community
5 Üyeler
41 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 16
Son 30 gün: 44
Her zaman: 2,582
