Ana içeriğe geç
Engage Wired Optical Mouse Top and Outer Shell Removal
Neye ihtiyacın var
  1. Engage Wired Optical Mouse Top and Outer Shell Removal, Engage Wired Optical Mouse Top and Outer Shell Removal: adım 1, 1 resimden 1.
    • Flip the mouse over and peel off the stickers on the perimeter of the bottom of the mouse.
  2. Engage Wired Optical Mouse Top and Outer Shell Removal: adım 2, 1 resimden 1.
    • Use the Phillips #1 screwdriver to remove four 5 mm screws from the bottom of the mouse.
    • Use the Phillips #1 screwdriver to remove the two 9 mm screws from the bottom of the mouse.
  3. Engage Wired Optical Mouse Top and Outer Shell Removal: adım 3, 3 resimden 1. Engage Wired Optical Mouse Top and Outer Shell Removal: adım 3, 3 resimden 2. Engage Wired Optical Mouse Top and Outer Shell Removal: adım 3, 3 resimden 3.
    • Grab the top shell of the mouse and lift up to remove.
  4. Engage Wired Optical Mouse Top and Outer Shell Removal: adım 4, 1 resimden 1.
    • The capacitors on this board can release stored electrical energy if touched.
    • Touch your capacitor discharge tool to the capacitor leads on the board to release the stored energy. If leads are inaccessible, wait until you've removed the board from the mouse body.
  5. Engage Wired Optical Mouse Top and Outer Shell Removal: adım 5, 2 resimden 1. Engage Wired Optical Mouse Top and Outer Shell Removal: adım 5, 2 resimden 2.
    • Use a spudger to pry underneath the white plug and pop it out to disconnect the upper board from the lower board.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
royceeklund
79 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-36, Regan Winter 2013 Cal Poly, Team 18-36, Regan Winter 2013 üyesi
CPSU-REGAN-W13S18G36
3 Üyeler
30 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 26
Her zaman: 3,491
