Ana içeriğe geç
Engine air filter replacement
Neye ihtiyacın var
    1. Engine air filter replacement, Accessing the engine hood: adım 1, 1 resimden 1.
      • Open the trunk.
      • Remove the trunk carpets.
      FixBot'a Sor
      Yorum Ekle
    2. Engine air filter replacement, Acessing the engine compartment: adım 2, 1 resimden 1.
      • Unscrew the 6 screws by hand or with a T50 socket.
      • Lift and set aside the engine hood.
      FixBot'a Sor
      Yorum Ekle
    1. Engine air filter replacement, Disassembling the airbox: adım 3, 2 resimden 1. Engine air filter replacement, Disassembling the airbox: adım 3, 2 resimden 2.
      • Unscrew the 2 Torx T25 screws.
      • Disglog the air filter lig by slightly pushing/pulling it forward then lifting it.
      FixBot'a Sor
      Yorum Ekle
      • Extract the used air filter.
      • Dust off the air box from any debris residing in it.
      • Optionnal but recommended: proceeed to a throttle body, MAP sensor and air manifold thermometer cleaning (see other tutorials).
      • Install the new air filter.
      FixBot'a Sor
      Yorum Ekle
    2. Engine air filter replacement, Reassembling the air box: adım 5, 2 resimden 1. Engine air filter replacement, Reassembling the air box: adım 5, 2 resimden 2.
      • Replace the lid by sliding the two notches.
      • Screw back the two T25 Torx screws while maintaining a slight pression on the lid.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Congratulations ! You replaced your engine air filter
6 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
fr en
100%
AntonioTwingo dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
AntonioTwingo
8.102 İtibar
45 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 19
Son 30 gün: 81
Her zaman: 2,226
