Ana içeriğe geç
Entry Door Weatherstripping Replacement
Neye ihtiyacın var
  1. Entry Door Weatherstripping Replacement, Weatherstripping: adım 1, 2 resimden 1. Entry Door Weatherstripping Replacement, Weatherstripping: adım 1, 2 resimden 2.
    • Use the putty knife to loosen the weatherstripping from the groove.
    • Push outwards from the groove using the putty knife, so the groove doesn't get damaged.
    • The groove is located behind the exterior of the door frame
  2. Entry Door Weatherstripping Replacement: adım 2, 3 resimden 1. Entry Door Weatherstripping Replacement: adım 2, 3 resimden 2. Entry Door Weatherstripping Replacement: adım 2, 3 resimden 3.
    • Pull out the Weatherstripping from the groove
    • Use the putty knife if assistance is needed by pushing the weatherstripping outward from the groove
  3. Entry Door Weatherstripping Replacement: adım 3, 1 resimden 1.
    • After removing the weatherstripping, measure the door frame using the measuring tape.
  4. Entry Door Weatherstripping Replacement: adım 4, 2 resimden 1. Entry Door Weatherstripping Replacement: adım 4, 2 resimden 2.
    • After measuring the door use a pen to mark the new weatherstrip and cut it with the scissors.
    • Be careful when handling scissors.
  5. Entry Door Weatherstripping Replacement: adım 5, 2 resimden 1. Entry Door Weatherstripping Replacement: adım 5, 2 resimden 2.
    • Using the putty knife, push the new weatherstripping into the door groove.
  6. Entry Door Weatherstripping Replacement: adım 6, 3 resimden 1. Entry Door Weatherstripping Replacement: adım 6, 3 resimden 2. Entry Door Weatherstripping Replacement: adım 6, 3 resimden 3.
    • Repeat the process from steps 1-5 for the weatherstrip for the top and left of the doorframe.
  7. Entry Door Weatherstripping Replacement: adım 7, 1 resimden 1.
    • Now measure the door’s width using the measuring tape.
  8. Entry Door Weatherstripping Replacement: adım 8, 2 resimden 1. Entry Door Weatherstripping Replacement: adım 8, 2 resimden 2.
    • Install the Door Sweep by drilling it in using a cordless drill.
    • Drill can be hazardous if not handled with care
Sonuç
Agilakumaran Shanmugalingam
157 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 20
Son 30 gün: 108
Her zaman: 6,825
