Ana içeriğe geç
Epiphone ES-335 PRO Pickguard Replacement
Neye ihtiyacın var
  1. Epiphone ES-335 PRO Pickguard Replacement, Pickguard: adım 1, 1 resimden 1.
    • Locate the screw closest to the neck of the guitar.
    • Use a phillips head #2 screwdriver to completely unscrew the 1.0 mm length screw.
    • Be sure to keep any screws together as you will use them again, unless the replacement pickguard has its own screws.
  2. Epiphone ES-335 PRO Pickguard Replacement: adım 2, 2 resimden 1. Epiphone ES-335 PRO Pickguard Replacement: adım 2, 2 resimden 2.
    • Using a phillips head #2 screwdriver, completely unscrew the 1.0 mm length screw.
    • Gently lift the pickguard off the body of the guitar.
Sonuç
1Rehber Yorum
very nice and simple demo, but where would you get a new pickguard, as Epiphone will not
supply them and other aftermarket guards will not fit.
peterattard1 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 18
Son 30 gün: 85
Her zaman: 5,331
