Ana içeriğe geç
Epiphone ES-335 PRO Tuner Replacement
Neye ihtiyacın var
    1. Epiphone ES-335 PRO Tuner Replacement, Strings: adım 1, 2 resimden 1. Epiphone ES-335 PRO Tuner Replacement, Strings: adım 1, 2 resimden 2.
      • Using the tuner, loosen the string by turning the tuner.
      • Continue to loosen the string until it is easily unwrapped and pulled out of the tuner.
      FixBot'a Sor
      Yorum Ekle
    2. Epiphone ES-335 PRO Tuner Replacement: adım 2, 1 resimden 1.
      • On the bridge of the guitar, push the string through the back until the other end is visible. Then grasp and pull the string all the way out.
      FixBot'a Sor
      Yorum Ekle
    1. Epiphone ES-335 PRO Tuner Replacement, Tuner: adım 3, 1 resimden 1.
      • Using a phillips head #2 screwdriver, unscrew the two 1.0 mm length screws on the sides of the tuner.
      • Be sure to keep track of the screws if you are using them for the new tuner, unless the new tuner has screws of its own.
      FixBot'a Sor
      Yorum Ekle
    2. Epiphone ES-335 PRO Tuner Replacement: adım 4, 1 resimden 1.
      • The tuner should come right out of the back of the head of the guitar.
      FixBot'a Sor
      Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 25
Her zaman: 1,795
