Ana içeriğe geç
Epiphone Les Paul Special Input Jack Replacement
Neye ihtiyacın var
  1. Epiphone Les Paul Special Input Jack Replacement, Input Jack: adım 1, 1 resimden 1.
    • Using a Phillips #1 screwdriver, remove the four 7 mm screws holding the input jack cover.
  2. Epiphone Les Paul Special Input Jack Replacement: adım 2, 1 resimden 1.
    • With a 12 mm wrench, remove the nut holding the input jack in place.
  3. Epiphone Les Paul Special Input Jack Replacement: adım 3, 2 resimden 1. Epiphone Les Paul Special Input Jack Replacement: adım 3, 2 resimden 2.
    • Lift off the tone control knob.
  4. Epiphone Les Paul Special Input Jack Replacement: adım 4, 1 resimden 1.
    • Using an 11 mm wrench, remove the nut of the tone control.
  5. Epiphone Les Paul Special Input Jack Replacement: adım 5, 1 resimden 1.
    • With a Phillips #1 screwdriver, remove the three 7 mm screws holding on the back plate.
  6. Epiphone Les Paul Special Input Jack Replacement: adım 6, 2 resimden 1. Epiphone Les Paul Special Input Jack Replacement: adım 6, 2 resimden 2.
    • Pull out the tone control.
  7. Epiphone Les Paul Special Input Jack Replacement: adım 7, 2 resimden 1. Epiphone Les Paul Special Input Jack Replacement: adım 7, 2 resimden 2.
    • Push the input jack through the body and pull it out.
  8. Epiphone Les Paul Special Input Jack Replacement: adım 8, 1 resimden 1.
    • The soldering iron is very hot. Avoid contact with skin, as well as the body of the instrument. When not in use, place it on a soldering iron stand.
    • Desolder the wires from the input jack.
  9. Epiphone Les Paul Special Input Jack Replacement: adım 9, 1 resimden 1.
    • Solder the wires to the input jack.
    • Repeat steps 7-1 in reverse order to put it all back together.
Sonuç
To get everything back into its original place, follow steps 1-7 in reverse order.
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 24
Son 30 gün: 86
Her zaman: 3,644
