Ana içeriğe geç
Epson EX90 Cooling Fan Replacement
Neye ihtiyacın var
  1. Epson EX90 Cooling Fan Replacement, Cooling Fan: adım 1, 2 resimden 1. Epson EX90 Cooling Fan Replacement, Cooling Fan: adım 1, 2 resimden 2.
    • Place the projector so that the bottom side is facing upwards
    • Remove the eight screws pictured from the bottom of the device.
    • Open the cover.
    • Be careful when opening the cover; a ribbon cable is still connecting the cover to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  2. Epson EX90 Cooling Fan Replacement: adım 2, 1 resimden 1.
    • Carefully remove the two parallel wire connectors which connect the fan to the corner of the motherboard.
    • Take care to record the port which each wire comes from, so as not to get your wires crossed.
    FixBot'a Sor
    Yorum Ekle
  3. Epson EX90 Cooling Fan Replacement: adım 3, 1 resimden 1.
    • Remove the three screws pictured, which hold the fan's frame in place.
    FixBot'a Sor
    Yorum Ekle
  4. Epson EX90 Cooling Fan Replacement: adım 4, 2 resimden 1. Epson EX90 Cooling Fan Replacement: adım 4, 2 resimden 2.
    • Remove fan and related assembly from projector.
    • Detach fan from housing.
    • If the fan is still in good condition, use a paper towel or cloth and clean out all the dust on your fan before reassembling.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Lucas Ketchie
160 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-3, Mellen Spring 2022 UMass Dartmouth, Team 2-3, Mellen Spring 2022 üyesi
UMASSD-MELLEN-S22S2G3
4 Üyeler
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 30
Her zaman: 447
