Ana içeriğe geç
Epson Home Cinema 2150 Exhaust Fan Replacement
Neye ihtiyacın var
  1. Epson Home Cinema 2150 Exhaust Fan Replacement, Projector Lamp: adım 1, 3 resimden 1. Epson Home Cinema 2150 Exhaust Fan Replacement, Projector Lamp: adım 1, 3 resimden 2. Epson Home Cinema 2150 Exhaust Fan Replacement, Projector Lamp: adım 1, 3 resimden 3.
    • Disconnect and cool the device to room temperature. Failure to do so may result in electric shock or minor burns.
    • Orient the Epson Home Cinema 2150 so that the large indented panel faces your direction.
    • Unscrew the single 6mm Phillips#2 holding screw from the access panel.
    • Slide the panel horizontally, then lift up to remove the access panel.
  2. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 2, 3 resimden 1. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 2, 3 resimden 2. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 2, 3 resimden 3.
    • Loosen and remove the two screws holding the lamp.
    • Remove two 9 mm Phillips #2 screws.
  3. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 3, 3 resimden 1. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 3, 3 resimden 2. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 3, 3 resimden 3.
    • Using four fingers, pull upwards on the lamp's plastic casing.
    • You may feel some resistance when pulling the lamp.
  4. Epson Home Cinema 2150 Exhaust Fan Replacement, Wireless connection board: adım 4, 3 resimden 1. Epson Home Cinema 2150 Exhaust Fan Replacement, Wireless connection board: adım 4, 3 resimden 2. Epson Home Cinema 2150 Exhaust Fan Replacement, Wireless connection board: adım 4, 3 resimden 3.
    • Remove the air filter cover. Grip the piece with two fingers above and below at the center.
    • Grab the air filter from the protruding tab and pull the filter out.
  5. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 5, 2 resimden 1. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 5, 2 resimden 2.
    • From the back of the projector remove three 6 mm Phillips #1 screws.
  6. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 6, 3 resimden 1. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 6, 3 resimden 2. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 6, 3 resimden 3.
    • From the device's underside, remove eleven 9.5 mm Phillips #1 screws.
    • Remove two 6 mm Phillips #1 screws.
    • Pull off remaining plastic molding.
  7. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 7, 2 resimden 1. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 7, 2 resimden 2.
    • From the lamp access slot, remove four 9.5 mm Philips #1 screws
  8. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 8, 3 resimden 1. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 8, 3 resimden 2. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 8, 3 resimden 3.
    • From the filter slot, unscrew two 9.5 mm #1 screws.
  9. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 9, 3 resimden 1. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 9, 3 resimden 2. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 9, 3 resimden 3.
    • Partially lift the top portion of the device housing.
    • Lifting too far or too hard may damage any cables between the housing and the motherboard.
  10. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 10, 3 resimden 1. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 10, 3 resimden 2. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 10, 3 resimden 3.
    • Disconnect the ribbon cable from the motherboard.
    • Ribbon cables are delicate. To avoid unnecessary stress to the cable, pull on the cable with the flat surface of two fingers.
  11. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 11, 3 resimden 1. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 11, 3 resimden 2. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 11, 3 resimden 3.
    • Remove three 5 mm Phillips #1 screws.
  12. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 12, 2 resimden 1. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 12, 2 resimden 2.
    • Press on the metal connector and firmly pull on the remaining ribbon cable.
  13. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 13, 3 resimden 1. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 13, 3 resimden 2. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 13, 3 resimden 3.
    • Pull the clips on the case with two fingers on opposite ends and remove the case.
  14. Epson Home Cinema 2150 Exhaust Fan Replacement, Speaker: adım 14, 3 resimden 1. Epson Home Cinema 2150 Exhaust Fan Replacement, Speaker: adım 14, 3 resimden 2. Epson Home Cinema 2150 Exhaust Fan Replacement, Speaker: adım 14, 3 resimden 3.
    • Pull up on the rear panel retaining clip.
    • Pull the rear panel away from the device to remove.
  15. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 15, 2 resimden 1. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 15, 2 resimden 2.
    • Disconnect the speaker wire from the motherboard.
    • Pull up at the end of the wire when removing the connector.
  16. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 16, 3 resimden 1. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 16, 3 resimden 2. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 16, 3 resimden 3.
    • Unwind the speaker wire through the metal chassis.
  17. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 17, 3 resimden 1. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 17, 3 resimden 2. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 17, 3 resimden 3.
    • Remove two 6mm Phillips #1 screws.
    • The speaker will fall out once screws are removed.
  18. Epson Home Cinema 2150 Exhaust Fan Replacement, Exhaust Fan: adım 18, 3 resimden 1. Epson Home Cinema 2150 Exhaust Fan Replacement, Exhaust Fan: adım 18, 3 resimden 2. Epson Home Cinema 2150 Exhaust Fan Replacement, Exhaust Fan: adım 18, 3 resimden 3.
    • Remove two 5 mm Phillips #1 screws.
  19. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 19, 3 resimden 1. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 19, 3 resimden 2. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 19, 3 resimden 3.
    • Disconnect a total of 10 motherboard connections.
    • Disconnect wires individually to avoid potential damage to the motherboard or the wires.
  20. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 20, 3 resimden 1. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 20, 3 resimden 2. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 20, 3 resimden 3.
    • Press on the metal connector and firmly pull to remove the remaining ribbon cable.
  21. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 21, 3 resimden 1. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 21, 3 resimden 2. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 21, 3 resimden 3.
    • Remove twelve 5 mm Phillips #1 screws.
    • Using both hands, carefully lift the first half of the motherboard.
  22. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 22, 2 resimden 1. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 22, 2 resimden 2.
    • Disconnect the three brown ribbon connectors from the board.
    • Ribbon cables are delicate. To avoid unnecessary stress to the cable, pull on the cable with the flat surface of a finger.
    • Remove four 5 mm Phillips #1 screws.
    • Remove two 3 mm Phillips #1 screws.
    • Pull upwards on the motherboard to remove it from the projector.
  23. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 23, 3 resimden 1. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 23, 3 resimden 2. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 23, 3 resimden 3.
    • Remove the 7.5 mm Phillips #1 screw.
    • Set the black plastic lens sliders to the side.
  24. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 24, 3 resimden 1. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 24, 3 resimden 2. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 24, 3 resimden 3.
    • Remove five 9.5 mm Phillips #1 screws.
    • Remove one 6.0 mm Phillips #2 screw.
    • This screw is located to the right of the rear 9.5 mm screw.
    • Remove the metal bracket by pulling upwards on its sides.
  25. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 25, 3 resimden 1. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 25, 3 resimden 2. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 25, 3 resimden 3.
    • Remove the 9.5 mm Phillips #1 screw located behind the power supply.
    • Unwind the fan cable from the power supply for better access to the screw.
    • Remove the 10 mm Phillips #1 screw.
  26. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 26, 3 resimden 1. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 26, 3 resimden 2. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 26, 3 resimden 3.
    • Move the fan cable to the side for clear access to the sensor below it.
    • Using pliers, pull upwards on the white sensor to remove it from the fan assembly.
  27. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 27, 3 resimden 1. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 27, 3 resimden 2. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 27, 3 resimden 3.
    • Remove two 9.5mm Phillips #1 screws.
  28. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 28, 3 resimden 1. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 28, 3 resimden 2. Epson Home Cinema 2150 Exhaust Fan Replacement: adım 28, 3 resimden 3.
    • Carefully lift upwards on the fan assembly to remove the fan from the projector.
Sonuç
Luis Garcia
577 İtibar
4 adet Kılavuz yazıldı
Ekip
CSU Los Angeles, Team 6-2, Adachi Fall 2022 CSU Los Angeles, Team 6-2, Adachi Fall 2022 üyesi
CSULA-ADACHI-F22S6G2
4 Üyeler
5 adet Kılavuz yazıldı
0 Guide Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 27
Her zaman: 715
