Ana içeriğe geç
Epson PPC650 Camera Case Replacement
Neye ihtiyacın var
  1. Epson PPC650 Camera Case Replacement, Case: adım 1, 3 resimden 1. Epson PPC650 Camera Case Replacement, Case: adım 1, 3 resimden 2. Epson PPC650 Camera Case Replacement, Case: adım 1, 3 resimden 3.
    • Locate the silver power button. Gently slide the button to the middle section labeled "off" to shut down the camera.
    • Remove the batteries from the battery compartment located on the underside of the camera.
    • Remove the SD card from the compartment located on the flat, left side of the camera.
    FixBot'a Sor
  2. Epson PPC650 Camera Case Replacement: adım 2, 1 resimden 1.
    • Remove the two screws on the rounded side of the camera.
    FixBot'a Sor
  3. Epson PPC650 Camera Case Replacement: adım 3, 2 resimden 1. Epson PPC650 Camera Case Replacement: adım 3, 2 resimden 2.
    • Remove the three screws on the flat side of the camera.
    • All of the silver screws go into the side of the camera that is silver.
    • All of the black screws go into the side of the camera that is black.
    FixBot'a Sor
  4. Epson PPC650 Camera Case Replacement: adım 4, 1 resimden 1.
    • Remove the four screws from the bottom of the camera.
    FixBot'a Sor
  5. Epson PPC650 Camera Case Replacement: adım 5, 3 resimden 1. Epson PPC650 Camera Case Replacement: adım 5, 3 resimden 2. Epson PPC650 Camera Case Replacement: adım 5, 3 resimden 3.
    • Separate the front and the back pieces of the camera's plastic casing using a spudger.
    • WARNING: When pulling the front plastic casing, be careful of the wires that are connected to the aperture control.
    • Use minimal force so that the plastic casing does not break.
    • When separating the small silver siding, the indicator for the view/off/playback may fall out.
    • The plastic viewing window located on the top of the camera may also become lose and fall out.
    FixBot'a Sor
Sonuç
Bir başkası bu kılavuzu tamamladı.
Brittany
113 İtibar
1 Kılavuz yazıldı
Ekip
Ohio State, Team 1-5, Buehl Spring 2013 Ohio State, Team 1-5, Buehl Spring 2013 üyesi
OSU-BUEHL-S13S1G5
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 14
Son 30 gün: 76
Her zaman: 538
