Ana içeriğe geç
Epson PPC650 Screen Replacement
Neye ihtiyacın var
    1. Epson PPC650 Screen Replacement, Case: adım 1, 3 resimden 1. Epson PPC650 Screen Replacement, Case: adım 1, 3 resimden 2. Epson PPC650 Screen Replacement, Case: adım 1, 3 resimden 3.
      • Locate the silver power button. Gently slide the button to the middle section labeled "off" to shut down the camera.
      • Remove the batteries from the battery compartment located on the underside of the camera.
      • Remove the SD card from the compartment located on the flat, left side of the camera.
      FixBot'a Sor
      Yorum Ekle
    2. Epson PPC650 Screen Replacement: adım 2, 1 resimden 1.
      • Remove the two screws on the rounded side of the camera.
      FixBot'a Sor
      Yorum Ekle
    3. Epson PPC650 Screen Replacement: adım 3, 2 resimden 1. Epson PPC650 Screen Replacement: adım 3, 2 resimden 2.
      • Remove the three screws on the flat side of the camera.
      • All of the silver screws go into the side of the camera that is silver.
      • All of the black screws go into the side of the camera that is black.
      FixBot'a Sor
      Yorum Ekle
    4. Epson PPC650 Screen Replacement: adım 4, 1 resimden 1.
      • Remove the four screws from the bottom of the camera.
      FixBot'a Sor
      Yorum Ekle
    5. Epson PPC650 Screen Replacement: adım 5, 3 resimden 1. Epson PPC650 Screen Replacement: adım 5, 3 resimden 2. Epson PPC650 Screen Replacement: adım 5, 3 resimden 3.
      • Separate the front and the back pieces of the camera's plastic casing using a spudger.
      • WARNING: When pulling the front plastic casing, be careful of the wires that are connected to the aperture control.
      • Use minimal force so that the plastic casing does not break.
      • When separating the small silver siding, the indicator for the view/off/playback may fall out.
      • The plastic viewing window located on the top of the camera may also become lose and fall out.
      FixBot'a Sor
      Yorum Ekle
    1. Epson PPC650 Screen Replacement, Screen: adım 6, 3 resimden 1. Epson PPC650 Screen Replacement, Screen: adım 6, 3 resimden 2. Epson PPC650 Screen Replacement, Screen: adım 6, 3 resimden 3.
      • Remove the copper sheet from the front and back paneling.
      • Use the spudger to unsolder the copper paneling.
      • Use the spudger to separate the back circuit board from the camera.
      FixBot'a Sor
      Yorum Ekle
    2. Epson PPC650 Screen Replacement: adım 7, 2 resimden 1. Epson PPC650 Screen Replacement: adım 7, 2 resimden 2.
      • The picture viewing screen is glued to the backing as well as wired in with pink and white wires.
      • Exert minimal force to pull the screen loose from the camera.
      • Remove the pink and white wiring from the internal paneling. These wires are soldered in.
      • Remove the orange data hookup cable that feeds into the back circuit board.
      FixBot'a Sor
      Yorum Ekle
      • Once all wires have been detached and the old screen has been removed place the new screen into the camera.
      • Insert data hookup into the back of the camera and into the new screen.
      • Re-solder the new pink and white wire onto the internal circuit board.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Anne
107 İtibar
1 Kılavuz yazıldı
Ekip
Ohio State, Team 1-5, Buehl Spring 2013 Ohio State, Team 1-5, Buehl Spring 2013 üyesi
OSU-BUEHL-S13S1G5
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 32
Her zaman: 800
