Ana içeriğe geç
Epson PowerLite 77c Button Panel Replacement
Neye ihtiyacın var
  1. Epson PowerLite 77c Button Panel Replacement, Top Panel: adım 1, 1 resimden 1.
    • Use a Phillips #0 screwdriver to remove the seven 5.0 mm screws on the base panel.
    • Pick up the projector with both hands, sandwiching the top and bottom of the projector together, and place it right-side-up, with the ports facing you.
    • Lift the top panel up.
    • Two connectors are holding the top panel to the motherboard; be careful not to damage them as you lift the top panel.
  2. Epson PowerLite 77c Button Panel Replacement: adım 2, 2 resimden 1. Epson PowerLite 77c Button Panel Replacement: adım 2, 2 resimden 2.
    • Flip the locking bar of the ZIF connector vertically, then delicately remove the ribbon cable.
    • Grip the cable connector as close as possible to the plug, then pull it straight up until it releases from the motherboard.
    • Remove the top panel.
  3. Epson PowerLite 77c Button Panel Replacement, Button Panel: adım 3, 1 resimden 1.
    • On the underside of the top panel, use a Phillips #0 to remove the four screws securing the button panel.
  4. Epson PowerLite 77c Button Panel Replacement: adım 4, 1 resimden 1.
    • Remove the button panel.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 76
