Ana içeriğe geç
Epson PowerLite 77c Fan Replacement
Neye ihtiyacın var
  1. Epson PowerLite 77c Fan Replacement, Lamp: adım 1, 1 resimden 1.
    • Use a Phillips #0 screwdriver to remove the one 5.0 mm screw from the lamp cover on the back of the device.
    FixBot'a Sor
    Yorum Ekle
  2. Epson PowerLite 77c Fan Replacement: adım 2, 1 resimden 1.
    • Slide the cover toward you, then lift it to remove it.
    FixBot'a Sor
    Yorum Ekle
  3. Epson PowerLite 77c Fan Replacement: adım 3, 2 resimden 1. Epson PowerLite 77c Fan Replacement: adım 3, 2 resimden 2.
    • Loosen the two 5.0 mm captive screws with a Phillips #0 screwdriver.
    • Captive screws cannot be fully removed. Simply loosen the captive screws until the lamp housing releases, but do not attempt to remove them.
    • Pinch the two release triggers to unlatch the lamp housing, and lift upward to remove it.
    FixBot'a Sor
    Yorum Ekle
  4. Epson PowerLite 77c Fan Replacement, Fan: adım 4, 1 resimden 1.
    • Use a Phillips #0 screwdriver to remove the seven 5.0 mm screws on the base panel.
    • Pick up the projector with both hands, sandwiching the top and bottom of the projector together, and place it right-side-up, with the ports facing you.
    • Lift the top panel up.
    • Two connectors are holding the top panel to the motherboard; be careful not to damage them as you lift the top panel.
    FixBot'a Sor
    Yorum Ekle
  5. Epson PowerLite 77c Fan Replacement: adım 5, 2 resimden 1. Epson PowerLite 77c Fan Replacement: adım 5, 2 resimden 2.
    • Flip the locking bar of the ZIF connector vertically, then delicately remove the ribbon cable.
    • Grip the cable connector as close as possible to the plug, then pull it straight up until it releases from the motherboard.
    • Remove the top panel.
    FixBot'a Sor
    Yorum Ekle
  6. Epson PowerLite 77c Fan Replacement: adım 6, 1 resimden 1.
    • Use a Phillips #0 screwdriver to remove the two 5.0 mm screws.
    FixBot'a Sor
    Yorum Ekle
  7. Epson PowerLite 77c Fan Replacement: adım 7, 2 resimden 1. Epson PowerLite 77c Fan Replacement: adım 7, 2 resimden 2.
    • Remove the one 5.0 mm screw on the right side of the gap with a Phillips #0 screwdriver.
    • Remove the one 5.0 mm screw on the left side of the gap with a Phillips #0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  8. Epson PowerLite 77c Fan Replacement: adım 8, 1 resimden 1.
    • On the right side of the motherboard, grip the plug labeled "PWR-FAN" and pull straight up to detach the fan from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  9. Epson PowerLite 77c Fan Replacement: adım 9, 2 resimden 1. Epson PowerLite 77c Fan Replacement: adım 9, 2 resimden 2.
    • Grip the fan and lift it up and out.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 18
Her zaman: 367
