Ana içeriğe geç
Epson PowerLite 77c Lamp Replacement
Neye ihtiyacın var
  1. Epson PowerLite 77c Lamp Replacement, Lamp: adım 1, 1 resimden 1.
    • Use a Phillips #0 screwdriver to remove the one 5.0 mm screw from the lamp cover on the back of the device.
    FixBot'a Sor
    Yorum Ekle
  2. Epson PowerLite 77c Lamp Replacement: adım 2, 1 resimden 1.
    • Slide the cover toward you, then lift it to remove it.
    FixBot'a Sor
    Yorum Ekle
  3. Epson PowerLite 77c Lamp Replacement: adım 3, 2 resimden 1. Epson PowerLite 77c Lamp Replacement: adım 3, 2 resimden 2.
    • Loosen the two 5.0 mm captive screws with a Phillips #0 screwdriver.
    • Captive screws cannot be fully removed. Simply loosen the captive screws until the lamp housing releases, but do not attempt to remove them.
    • Pinch the two release triggers to unlatch the lamp housing, and lift upward to remove it.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Gretchen Thomas
211 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 21
Her zaman: 506
