Ana içeriğe geç
Epson PowerLite 822 Plus Lamp Replacement
Neye ihtiyacın var
  1. Epson PowerLite 822 Plus Lamp Replacement, Lamp: adım 1, 1 resimden 1.
    • If you just used the projector you will want to let it sit for about an hour to cool off.
    • If you have not used the projector within the past few hours you are ready to get to work.
  2. Epson PowerLite 822 Plus Lamp Replacement: adım 2, 2 resimden 1. Epson PowerLite 822 Plus Lamp Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #2 screwdriver to remove the 6 mm screw that holds the lamp cover in place.
  3. Epson PowerLite 822 Plus Lamp Replacement: adım 3, 3 resimden 1. Epson PowerLite 822 Plus Lamp Replacement: adım 3, 3 resimden 2. Epson PowerLite 822 Plus Lamp Replacement: adım 3, 3 resimden 3.
    • Apply pressure to the lamp cover, pulling it towards the end of the projector.
    • Pop the lamp cover off, exposing the lamp.
  4. Epson PowerLite 822 Plus Lamp Replacement: adım 4, 3 resimden 1. Epson PowerLite 822 Plus Lamp Replacement: adım 4, 3 resimden 2. Epson PowerLite 822 Plus Lamp Replacement: adım 4, 3 resimden 3.
    • There are two 9mm screws which have already been loosened. These screws do not come all the way out.
    • Grip the finger hold and pull it straight out of the projector.
  5. Epson PowerLite 822 Plus Lamp Replacement: adım 5, 1 resimden 1.
    • After pulling it straight up by the finger hold the lamp will be revealed and ready to be replaced.
Sonuç
Emma Richey
915 İtibar
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 5
Her zaman: 115
