Ana içeriğe geç
Epson PowerLite 822 Plus Projector Lens Replacement
Neye ihtiyacın var
  1. Epson PowerLite 822 Plus Projector Lens Replacement, Motherboard: adım 1, 1 resimden 1.
    • Flip the projector over.
    • Remove all 8 screws on the bottom of the projector.
  2. Epson PowerLite 822 Plus Projector Lens Replacement: adım 2, 2 resimden 1. Epson PowerLite 822 Plus Projector Lens Replacement: adım 2, 2 resimden 2.
    • Now, flip the projector back over and pry the top of it open revealing the inside of the projector.
  3. Epson PowerLite 822 Plus Projector Lens Replacement: adım 3, 2 resimden 1. Epson PowerLite 822 Plus Projector Lens Replacement: adım 3, 2 resimden 2.
    • Use the spudger to disconnect it from the motherboard.
  4. Epson PowerLite 822 Plus Projector Lens Replacement: adım 4, 2 resimden 1. Epson PowerLite 822 Plus Projector Lens Replacement: adım 4, 2 resimden 2.
    • Using your finger gently move back and forth the JST cable that connects the top to the motherboard.
    • Now completely take off the top of the projector.
  5. Epson PowerLite 822 Plus Projector Lens Replacement: adım 5, 2 resimden 1. Epson PowerLite 822 Plus Projector Lens Replacement: adım 5, 2 resimden 2.
    • Remove the 3 screws that secure the motherboard in place.
  6. Epson PowerLite 822 Plus Projector Lens Replacement: adım 6, 3 resimden 1. Epson PowerLite 822 Plus Projector Lens Replacement: adım 6, 3 resimden 2. Epson PowerLite 822 Plus Projector Lens Replacement: adım 6, 3 resimden 3.
    • Gently move back and forth the 11 JST connectors until they come out.
  7. Epson PowerLite 822 Plus Projector Lens Replacement: adım 7, 2 resimden 1. Epson PowerLite 822 Plus Projector Lens Replacement: adım 7, 2 resimden 2.
    • With the spudger lift the red plastic tabs from their connectors.
  8. Epson PowerLite 822 Plus Projector Lens Replacement: adım 8, 3 resimden 1. Epson PowerLite 822 Plus Projector Lens Replacement: adım 8, 3 resimden 2. Epson PowerLite 822 Plus Projector Lens Replacement: adım 8, 3 resimden 3.
    • Lift the motherboard and disconnect the JST connector underneath.
  9. Epson PowerLite 822 Plus Projector Lens Replacement: adım 9, 1 resimden 1.
    • Now, the motherboard is completely removed from the projector and you are ready to replace it.
  10. Epson PowerLite 822 Plus Projector Lens Replacement, Projector Lens: adım 10, 3 resimden 1. Epson PowerLite 822 Plus Projector Lens Replacement, Projector Lens: adım 10, 3 resimden 2. Epson PowerLite 822 Plus Projector Lens Replacement, Projector Lens: adım 10, 3 resimden 3.
    • Use a Phillips #2 screwdriver to remove the four 6 mm screws that hold together the fan bracket.
  11. Epson PowerLite 822 Plus Projector Lens Replacement: adım 11, 2 resimden 1. Epson PowerLite 822 Plus Projector Lens Replacement: adım 11, 2 resimden 2.
    • Use a Phillips #2 screwdriver to remove the four 6 mm screws that secure the projector.
  12. Epson PowerLite 822 Plus Projector Lens Replacement: adım 12, 2 resimden 1. Epson PowerLite 822 Plus Projector Lens Replacement: adım 12, 2 resimden 2.
    • Pull out the loose projector and it is ready to be replaced.
Sonuç
Emma Richey
915 İtibar
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 8
Her zaman: 81
