Ana içeriğe geç
Epson PowerLite S4 Exhaust Fan Replacement
Neye ihtiyacın var
  1. Epson PowerLite S4 Exhaust Fan Replacement, Exhaust Fan: adım 1, 1 resimden 1.
    • With the bottom of the projector facing you, use a Phillips #00 screwdriver to remove the seven screws.
  2. Epson PowerLite S4 Exhaust Fan Replacement: adım 2, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove one screw on the backside of the projector.
    • Slide the panel off.
  3. Epson PowerLite S4 Exhaust Fan Replacement: adım 3, 1 resimden 1.
    • Lift the top frame from the backside of the projector, with care not to damage any connections.
    • Disconnect the two cables from the motherboard.
  4. Epson PowerLite S4 Exhaust Fan Replacement: adım 4, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove one screw.
    • Lift the fan and its mount up and out of the projector.
  5. Epson PowerLite S4 Exhaust Fan Replacement: adım 5, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the two screws securing the fan to its housing, then gently pull them apart to separate each piece.
Sonuç
To reassemble your device, follow these instructions in reverse order using the new exhaust fan.
Bir başkası bu kılavuzu tamamladı.
Max Askew
221 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-1, Petersen Spring 2022 UMass Dartmouth, Team 1-1, Petersen Spring 2022 üyesi
UMASSD-PETERSEN-S22S1G1
3 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 14
Her zaman: 182
