Ana içeriğe geç
Epson Powerlite 410W Lamp Replacement
Neye ihtiyacın var
  1. Epson Powerlite 410W Lamp Replacement, Lamp: adım 1, 1 resimden 1.
    • Press the power button located on top of the projector.
    • Remember to let the projector cool off completely after turning off the power before beginning the repair.
  2. Epson Powerlite 410W Lamp Replacement: adım 2, 3 resimden 1. Epson Powerlite 410W Lamp Replacement: adım 2, 3 resimden 2. Epson Powerlite 410W Lamp Replacement: adım 2, 3 resimden 3.
    • Loosen the single captive screw holding the lamp cover in place using a Phillips #2 screwdriver.
    • Slide the cover out, then lift it off and place to the side.
  3. Epson Powerlite 410W Lamp Replacement: adım 3, 1 resimden 1.
    • Loosen the two captive screws that hold the lamp in place using a Phillips #2 screwdriver.
  4. Epson Powerlite 410W Lamp Replacement: adım 4, 1 resimden 1.
    • Use your hands to pull the lamp straight out of the projector.
    • When inserting the new lamp, push the lamp down firmly, where the label “PUSH” appears.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 8
Son 30 gün: 15
Her zaman: 257
