Ana içeriğe geç
Epson Powerlite 410W Motherboard Replacement
Neye ihtiyacın var
  1. Epson Powerlite 410W Motherboard Replacement, Top Cover: adım 1, 1 resimden 1.
    • Press the power button located on top of the projector.
    • Remember to let the projector cool off completely after turning off the power before beginning the repair.
  2. Epson Powerlite 410W Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove eight screws from the bottom of the device using a Phillips #00 screwdriver.
  3. Epson Powerlite 410W Motherboard Replacement: adım 3, 3 resimden 1. Epson Powerlite 410W Motherboard Replacement: adım 3, 3 resimden 2. Epson Powerlite 410W Motherboard Replacement: adım 3, 3 resimden 3.
    • Turn the projector so the power button is on top.
    • Gently pull up the cover until it pops off.
    • Do not pull too far; a ribbon cable still connects the top cover to the motherboard.
    • Disconnect the ribbon cable that attaches the cover to the motherboard.
    • Remove the cover and place to the side.
  4. Epson Powerlite 410W Motherboard Replacement, Motherboard: adım 4, 2 resimden 1. Epson Powerlite 410W Motherboard Replacement, Motherboard: adım 4, 2 resimden 2.
    • Remove the two screws holding down the motherboard using a Phillips #00 screwdriver.
    • Remove the four screws holding down the I/O board using a Phillips #00 screwdriver.
  5. Epson Powerlite 410W Motherboard Replacement: adım 5, 1 resimden 1.
    • Remove the seven cables that are running to the motherboard by pulling them out of their sockets.
  6. Epson Powerlite 410W Motherboard Replacement: adım 6, 3 resimden 1. Epson Powerlite 410W Motherboard Replacement: adım 6, 3 resimden 2. Epson Powerlite 410W Motherboard Replacement: adım 6, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Using a plastic opening tool, gently pry up the black tabs holding in the ribbon cables on the motherboard.
    • Using tweezers, gently pull the ribbon cables out of the sockets.
  7. Epson Powerlite 410W Motherboard Replacement: adım 7, 1 resimden 1.
    • Gently pull the motherboard up and tilt it back, revealing the last cable attached to the motherboard. Disconnect this cable.
    • Remove the motherboard from the projector.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 13
Her zaman: 94
