Ana içeriğe geç
Epson Powerlite S5 Projection Lamp Replacement
Neye ihtiyacın var
  1. Epson Powerlite S5 Projection Lamp Replacement, Projection Lamp: adım 1, 2 resimden 1. Epson Powerlite S5 Projection Lamp Replacement, Projection Lamp: adım 1, 2 resimden 2.
    • Make sure the power is off before beginning.
    • Unplug the projector's power cord from the wall.
    • Allow the projection lamp to cool completely before replacing.
  2. Epson Powerlite S5 Projection Lamp Replacement: adım 2, 2 resimden 1. Epson Powerlite S5 Projection Lamp Replacement: adım 2, 2 resimden 2.
    • Using a Phillip's head screwdriver, remove the screw from the back.
  3. Epson Powerlite S5 Projection Lamp Replacement: adım 3, 3 resimden 1. Epson Powerlite S5 Projection Lamp Replacement: adım 3, 3 resimden 2. Epson Powerlite S5 Projection Lamp Replacement: adım 3, 3 resimden 3.
    • Slide the cover back.
    • Lift cover to remove.
  4. Epson Powerlite S5 Projection Lamp Replacement: adım 4, 3 resimden 1. Epson Powerlite S5 Projection Lamp Replacement: adım 4, 3 resimden 2. Epson Powerlite S5 Projection Lamp Replacement: adım 4, 3 resimden 3.
    • Locate the two screws on either side of the projection lamp.
    • Using a Phillip's head screwdriver, loosen the two screws.
    • The screws only loosen. You don't have to worry about them falling out.
  5. Epson Powerlite S5 Projection Lamp Replacement: adım 5, 3 resimden 1. Epson Powerlite S5 Projection Lamp Replacement: adım 5, 3 resimden 2. Epson Powerlite S5 Projection Lamp Replacement: adım 5, 3 resimden 3.
    • Grip the two plastic bars on the top of the old projection lamp.
    • Remove the projection lamp by pulling straight up.
    • If there is any lamp breakage, handle the shards carefully to avoid injury.
Sonuç
Greg Brown
121 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 1,221
