Ana içeriğe geç
Epson Stylus NX230 Motor Replacement
Neye ihtiyacın var
  1. Epson Stylus NX230 Motor Replacement, Motherboard: adım 1, 1 resimden 1.
    • Check to make sure the printer is unplugged to prevent electric shock.
  2. Epson Stylus NX230 Motor Replacement: adım 2, 2 resimden 1. Epson Stylus NX230 Motor Replacement: adım 2, 2 resimden 2.
    • Align your printer so that the front buttons face to the right.
    • Remove the 3mm Phillips #2 screw in the hole in the top left corner. This screw attaches the side panel to the printer.
    • Store the screws in a safe place so you can access them later.
  3. Epson Stylus NX230 Motor Replacement: adım 3, 1 resimden 1.
    • Flip and remove the top of the printer up so that you can see the inside.
    • There is a white strip in the top right corner of the printer called the ribbon cable.
    • Make sure that the ribbon cable does not detach from the printer to prevent damaging the connection.
  4. Epson Stylus NX230 Motor Replacement: adım 4, 2 resimden 1. Epson Stylus NX230 Motor Replacement: adım 4, 2 resimden 2.
    • Align the printer so the front button panel faces to the right.
    • Remove the 3mm Phillips #2 screw on the side of the printer in the top left corner.
    • Store the screw in a safe place so you can access it later.
  5. Epson Stylus NX230 Motor Replacement: adım 5, 2 resimden 1. Epson Stylus NX230 Motor Replacement: adım 5, 2 resimden 2.
    • Take the right side of the bar of plastic that runs across the top of the inside of the printer and push it towards the left side of the printer.
    • Take the left side of the bar and push it to the left and then to the right.
  6. Epson Stylus NX230 Motor Replacement: adım 6, 3 resimden 1. Epson Stylus NX230 Motor Replacement: adım 6, 3 resimden 2. Epson Stylus NX230 Motor Replacement: adım 6, 3 resimden 3.
    • Using your hands, detach the side panel from the printer.
    • Take extra care with the locking mechanisms, which help keep the side panel on the printer.
    • You may need to use the plastic opening tools to pry apart the locking mechanisms.
  7. Epson Stylus NX230 Motor Replacement: adım 7, 1 resimden 1.
    • Remove the two 3mm Phillips #2 screws attaching motherboard to the printer.
    • The motherboard can now be removed from the printer.
  8. Epson Stylus NX230 Motor Replacement, Motor: adım 8, 1 resimden 1.
    • Remove the four 3mm Phillips #2 screws attaching the motor to the printer.
  9. Epson Stylus NX230 Motor Replacement: adım 9, 1 resimden 1.
    • Place the printer on it's side so that the motherboard's location is facing up.
    • Push the motor up and out of the hole that it is in.
    • The motor will slide out of the hole at the top after that.
Sonuç
Kimberly Pugel
404 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-1, Forte Spring 2014 Cal Poly, Team 6-1, Forte Spring 2014 üyesi
CPSU-FORTE-S14S6G1
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 950
