Ana içeriğe geç
Epson Stylus NX240 Side Buttons Replacement
Neye ihtiyacın var
  1. Epson Stylus NX240 Side Buttons Replacement, Side Buttons: adım 1, 2 resimden 1. Epson Stylus NX240 Side Buttons Replacement, Side Buttons: adım 1, 2 resimden 2.
    • Go to the left side of the printer and locate the control panel with the buttons on it.
    • Take a plastic opening tool and stick it in the crack between the top of the panel and the body of the printer.
    • Pry the cover of the panel away from the body of the printer until the panel releases from the body of the printer.
  2. Epson Stylus NX240 Side Buttons Replacement: adım 2, 1 resimden 1.
    • Carefully lift up the panel cover and turn it to its side so that the buttons are facing towards the rest of the printer.
    • Notice that the panel cover is attached to the printer with a ribbon cable. The ribbon cable must stay connected to the body of the printer or else the buttons will be unresponsive once replaced.
  3. Epson Stylus NX240 Side Buttons Replacement: adım 3, 1 resimden 1.
    • Remove the six 3mm Phillips #2 screws connecting the control panel to the circuit board.
  4. Epson Stylus NX240 Side Buttons Replacement: adım 4, 1 resimden 1.
    • After unscrewing, carefully lift the plastic part of the control panel away from the circuit board.
    • The plastic part of the control panel is now separate.
  5. Epson Stylus NX240 Side Buttons Replacement: adım 5, 1 resimden 1.
    • Flip over the plastic part of the now separated control panel.
    • Remove the buttons by pulling them up with your fingers.
  6. Epson Stylus NX240 Side Buttons Replacement: adım 6, 1 resimden 1.
    • All parts should be separate now to clean or replace.
Sonuç
Joshua Fabel
104 İtibar
1 Kılavuz yazıldı
Ekip
University of Maine, Team 2-4, Diaz Fall 2016 University of Maine, Team 2-4, Diaz Fall 2016 üyesi
UMAINE-DIAZ-F16S2G4
4 Üyeler
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 563
