Ana içeriğe geç
Epson Stylus Photo 1400 Housing Replacement
Neye ihtiyacın var
  1. Epson Stylus Photo 1400 Housing Replacement, Housing: adım 1, 1 resimden 1.
    • Turn off the printer.
    • Disconnect all data connections coming into the printer such as USB, networkd cables, firewire, etc. as well as removing the power cord.
  2. Epson Stylus Photo 1400 Housing Replacement: adım 2, 2 resimden 1. Epson Stylus Photo 1400 Housing Replacement: adım 2, 2 resimden 2.
    • Locate the IEEE cover in the back.
    • Gently slide the cover to the right to unlatch, then pull to remove it.
  3. Epson Stylus Photo 1400 Housing Replacement: adım 3, 2 resimden 1. Epson Stylus Photo 1400 Housing Replacement: adım 3, 2 resimden 2.
    • Using a Phillips #2 screwdriver, remove the four 10 mm screws shown.
    • Remove the 6 mm screw that holds the rear housing in place.
  4. Epson Stylus Photo 1400 Housing Replacement: adım 4, 2 resimden 1. Epson Stylus Photo 1400 Housing Replacement: adım 4, 2 resimden 2.
    • Remove the rear housing by pulling it backwards.
  5. Epson Stylus Photo 1400 Housing Replacement: adım 5, 3 resimden 1. Epson Stylus Photo 1400 Housing Replacement: adım 5, 3 resimden 2. Epson Stylus Photo 1400 Housing Replacement: adım 5, 3 resimden 3.
    • Insert a plastic opening tool into the cutouts of the lower housing.
    • Release the two tabs of the side housing by lifting the tool in an upward motion.
    • Remove the side housing by pulling it outwards.
  6. Epson Stylus Photo 1400 Housing Replacement: adım 6, 2 resimden 1. Epson Stylus Photo 1400 Housing Replacement: adım 6, 2 resimden 2.
    • Both side housings are attached by the same type of mechanism.
    • Using the same method, remove the other side housing.
  7. Epson Stylus Photo 1400 Housing Replacement: adım 7, 3 resimden 1. Epson Stylus Photo 1400 Housing Replacement: adım 7, 3 resimden 2. Epson Stylus Photo 1400 Housing Replacement: adım 7, 3 resimden 3.
    • Lift the paper support.
    • Open the printer cover and front cover.
  8. Epson Stylus Photo 1400 Housing Replacement: adım 8, 3 resimden 1. Epson Stylus Photo 1400 Housing Replacement: adım 8, 3 resimden 2. Epson Stylus Photo 1400 Housing Replacement: adım 8, 3 resimden 3.
    • Remove the four 10 mm Phillips #2 screws from the sides of the printer.
    • Remove the three 6 mm Phillips #2 screws.
  9. Epson Stylus Photo 1400 Housing Replacement: adım 9, 2 resimden 1. Epson Stylus Photo 1400 Housing Replacement: adım 9, 2 resimden 2.
    • Detach the tabs from the pins on each side by pulling it outwards.
  10. Epson Stylus Photo 1400 Housing Replacement: adım 10, 2 resimden 1. Epson Stylus Photo 1400 Housing Replacement: adım 10, 2 resimden 2.
    • Remove the two 10 mm Phillips #2 screws on the front of the printer.
  11. Epson Stylus Photo 1400 Housing Replacement: adım 11, 3 resimden 1. Epson Stylus Photo 1400 Housing Replacement: adım 11, 3 resimden 2. Epson Stylus Photo 1400 Housing Replacement: adım 11, 3 resimden 3.
    • Disconnect the two cables on the side by carefully pulling it outwards.
    • You may need to gently rock the two cables up and down while pulling.
  12. Epson Stylus Photo 1400 Housing Replacement: adım 12, 2 resimden 1. Epson Stylus Photo 1400 Housing Replacement: adım 12, 2 resimden 2.
    • Remove the upper housing by lifting it upwards.
    • It's easier to lift the housing by gripping it from the bottom.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Larry Huang
1.004 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-11, Regan Fall 2011 Cal Poly, Team 17-11, Regan Fall 2011 üyesi
CPSU-REGAN-F11S17G11
4 Üyeler
12 adet Kılavuz yazıldı
Bir Yorum
Thank you so much, Larry! I am repurposing my 1400 for sublimation printing and need to get the print head a little easier than standard methods! Much appreciated!
ryan Caputo - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 19
Her zaman: 7,543
