Ana içeriğe geç
Epson Stylus Photo 1400 Ink cartridge replacement
Neye ihtiyacın var
  1. Epson Stylus Photo 1400 Ink cartridge replacement, ink cartridge: adım 1, 2 resimden 1. Epson Stylus Photo 1400 Ink cartridge replacement, ink cartridge: adım 1, 2 resimden 2.
    • Open cover of the printer.
    • Open the cartridge cover by pressing down on the tab and lifting it up.
  2. Epson Stylus Photo 1400 Ink cartridge replacement: adım 2, 2 resimden 1. Epson Stylus Photo 1400 Ink cartridge replacement: adım 2, 2 resimden 2.
    • Grab the sides of the ink cartridge and pull it out.
    • Replace ink cartridge with brand new ink cartridge.
  3. Epson Stylus Photo 1400 Ink cartridge replacement: adım 3, 2 resimden 1. Epson Stylus Photo 1400 Ink cartridge replacement: adım 3, 2 resimden 2.
    • Close cartridge cover.
    • Close cover of the printer.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Larry Huang
1.004 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-11, Regan Fall 2011 Cal Poly, Team 17-11, Regan Fall 2011 üyesi
CPSU-REGAN-F11S17G11
4 Üyeler
12 adet Kılavuz yazıldı
5 Yorum
I cannot change the ink cartridges because when I press the Ink button they will not stop in a position where I can open the container. Nothing I've tried works -- can you help please? URGENT!!!
David Hardy - Yanıt
I actually found this quite easy because of your guide. There was no issue at all with replacing the ink cartridge in my printer and now I can print again! Is there anything else I need to worry about after I put the cartridge in? http://tonertown.com.au
chrishowell562 - Yanıt
You missed the part where you tell people how to get the cartridge to a position where you can open it. Mine is block because it is over to the side too far.
Paul M - Yanıt
Poor instructions on how to get ink cartridge holder in right position.
rpttrsn - Yanıt
Instruction intimates the ink carriage will be in position when parked. Not so…with it parked in the extreme right, you cannot get the ink cover open. jdw
joe waldroff - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 20
Her zaman: 10,128
