Ana içeriğe geç
Epson Stylus Photo 820 Ink Cartridges Replacement
  1. Epson Stylus Photo 820 Ink Cartridges Replacement, Ink Cartridges: adım 1, 1 resimden 1.
    • When you are low on ink your green power light will be flashing and your error light will stay a solid red.
  2. Epson Stylus Photo 820 Ink Cartridges Replacement: adım 2, 2 resimden 1. Epson Stylus Photo 820 Ink Cartridges Replacement: adım 2, 2 resimden 2.
    • Lift the printer window open by pulling up on the tab.
    • Your printer should now be in the same state as shown in the second picture.
  3. Epson Stylus Photo 820 Ink Cartridges Replacement: adım 3, 2 resimden 1. Epson Stylus Photo 820 Ink Cartridges Replacement: adım 3, 2 resimden 2.
    • Press the button on the far right to get your ink cartridge holders to slide over. (See the second picture)
  4. Epson Stylus Photo 820 Ink Cartridges Replacement: adım 4, 3 resimden 1. Epson Stylus Photo 820 Ink Cartridges Replacement: adım 4, 3 resimden 2. Epson Stylus Photo 820 Ink Cartridges Replacement: adım 4, 3 resimden 3.
    • Press the tabs with the upward facing arrows to open the hatches as shown in the first picture.
    • Remove the ink cartridge(s) that needs to be replaced. The black cartridge is on the left and the color cartridge is on the right.
    • Make sure your cartridges are the same as the ones shown in the third picture. Non-Epson ink cartridges may not be recognized by your printer.
  5. Epson Stylus Photo 820 Ink Cartridges Replacement: adım 5, 3 resimden 1. Epson Stylus Photo 820 Ink Cartridges Replacement: adım 5, 3 resimden 2. Epson Stylus Photo 820 Ink Cartridges Replacement: adım 5, 3 resimden 3.
    • Insert your new ink cartridges and close the hatches.
    • Close your printer door and push the ink cartridge button on the far right and again.
    • After your ink charges you're ready to print!
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Alex Lin
99 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-68, Walters Spring 2011 Cal Poly, Team 20-68, Walters Spring 2011 üyesi
CPSU-WALTERS-S11S20G68
4 Üyeler
12 adet Kılavuz yazıldı
Bir Yorum
I pushed the 3rd button so the cartridge holder will slide over, it will not move.
I tried unplugging the printer and plugging it back in & repower it up. still 'stuck' to the right.
I need to change the black ink. can you help? thank you!
tina - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 2,886
