Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
When you are low on ink your green power light will be flashing and your error light will stay a solid red.
Lift the printer window open by pulling up on the tab.
Your printer should now be in the same state as shown in the second picture.
Press the button on the far right to get your ink cartridge holders to slide over. (See the second picture)
Press the tabs with the upward facing arrows to open the hatches as shown in the first picture.
Remove the ink cartridge(s) that needs to be replaced. The black cartridge is on the left and the color cartridge is on the right.
Insert your new ink cartridges and close the hatches.
Close your printer door and push the ink cartridge button on the far right and again.
After your ink charges you're ready to print!
Bir başkası bu kılavuzu tamamladı.
