Ana içeriğe geç
Epson VS250 Lamp Replacement
Neye ihtiyacın var
  1. Epson VS250 Lamp Replacement, Lamp: adım 1, 1 resimden 1.
    • Place the projector on a flat surface.
    • Orient the projector so that the the word "Epson" is facing you.
    • Use Phillips #1 screwdriver to loosen the 10 mm screw on the top right corner of the projector.
    • The screw does not need to come all the way out.
    FixBot'a Sor
    Yorum Ekle
  2. Epson VS250 Lamp Replacement: adım 2, 1 resimden 1.
    • Slide the cover to the right and lift the cover up and out to remove.
    FixBot'a Sor
    Yorum Ekle
  3. Epson VS250 Lamp Replacement: adım 3, 1 resimden 1.
    • Use a Phillips #1 screwdriver to loosen the two 10 mm screws that hold the lamp in place.
    • The two 10 mm screws do not need to come all the way out. Just ensure they are loose.
    FixBot'a Sor
    Yorum Ekle
  4. Epson VS250 Lamp Replacement: adım 4, 2 resimden 1. Epson VS250 Lamp Replacement: adım 4, 2 resimden 2.
    • After loosening both screws, remove the lamp from the projector by pulling it up and out.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Warren Cutlip
604 İtibar
5 adet Kılavuz yazıldı
Ekip
Clemson, Team 4-2, Hunter Fall 2021 Clemson, Team 4-2, Hunter Fall 2021 üyesi
CLEM-HUNTER-F21S4G2
5 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 18
Her zaman: 904
