Ana içeriğe geç
Equity Alarm Clock 13014 Alarm Replacement
Neye ihtiyacın var
  1. Equity Alarm Clock 13014 Alarm Replacement, Alarm: adım 1, 3 resimden 1. Equity Alarm Clock 13014 Alarm Replacement, Alarm: adım 1, 3 resimden 2. Equity Alarm Clock 13014 Alarm Replacement, Alarm: adım 1, 3 resimden 3.
    • Use a spudger to open and detach the wiring from the box holding the battery.
    • Insert the flat end of the spudger on both sides of the box, gently pry it open and detach it from the clock.
    • Be careful while handling the box and clock to avoid any damage or injury.
    FixBot'a Sor
    Yorum Ekle
  2. Equity Alarm Clock 13014 Alarm Replacement: adım 2, 1 resimden 1.
    • Use your fingers to remove the box.
    • Be careful not to apply too much pressure or force that could damage the box.
    FixBot'a Sor
    Yorum Ekle
  3. Equity Alarm Clock 13014 Alarm Replacement: adım 3, 2 resimden 1. Equity Alarm Clock 13014 Alarm Replacement: adım 3, 2 resimden 2.
    • Use a soldering iron to melt the solder on each wire connection to safely remove the wires.
    FixBot'a Sor
    Yorum Ekle
  4. Equity Alarm Clock 13014 Alarm Replacement: adım 4, 2 resimden 1. Equity Alarm Clock 13014 Alarm Replacement: adım 4, 2 resimden 2.
    • To replace the wiring box, use your hand to remove the old one and install a new one in its place.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Alaa
335 İtibar
2 adet Kılavuz yazıldı
1Rehber Yorum
Is there someone I can send my alarm clock to for fixing? IF so, how much would it cost? I do not have the tools nor the know how to do it. Most likely, the alarm will have to be replaced. The little motor on the inside is not working when it is time for it to go off. It does not move the ringer/clanger. Thanks,
mariacarbonell@comcast.net
Maria Carbonell - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 28
Son 30 gün: 92
Her zaman: 4,921
