Ana içeriğe geç
Ernie Ball Volume Pedal Spring and String Replacement
Neye ihtiyacın var
  1. Ernie Ball Volume Pedal Spring and String Replacement, Spring and String: adım 1, 1 resimden 1.
    • Insert the loop of the short cord through eyelet from the rear of the pedal Pass cord down and under rear black pulley, and attach spring to loop.
    • The eyelet is located under the top plate, toward front of the pedal.
    • Place the cord inside the pedal, under the main cross shaft, and let it lie there for now.
    • Move the pedal to the “toe-up” position.
    • Insert the loop of the long cord through the rear side of eyelet toward the front of the pedal.
  2. Ernie Ball Volume Pedal Spring and String Replacement: adım 2, 1 resimden 1.
    • Rotate the brass pot pulley to full the counter-clockwise position.
    • Wind the cord clockwise 3 times from back side of brass pulley.
    • The Cord must be wound from the inside of the pulley (nearest to the black mounting block), to the outside.
    • Do not twist cord or wind it over itself.
  3. Ernie Ball Volume Pedal Spring and String Replacement: adım 3, 1 resimden 1.
    • From the side of the open pedal, hold spring in place while carefully attaching the long cord's loop to remaining end of the spring.
    • You may want to make a small hooking mechanism, possibly out of a paper clip, to perform this task.
  4. Ernie Ball Volume Pedal Spring and String Replacement: adım 4, 1 resimden 1.
    • Pull the long cord forward and onto the front black pulley. Make sure that the short cord is in place on the back black pulley.
  5. Ernie Ball Volume Pedal Spring and String Replacement: adım 5, 1 resimden 1.
    • From the front of the open pedal, gently pull the spring forward while pressing firmly on the rear of top plate. Continue to do so until it bottoms out.
    • Continue pulling the spring forward, and turn brass pot pulley to full counter-clockwise position. This correctly seats the pot and cord.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Corey Brown
8.682 İtibar
11 adet Kılavuz yazıldı
Bir Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 21
Her zaman: 5,815
