Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
This guide will show you how to replace the string and spring using the spring and string kit sold by Ernie Ball. This kit is compatible for volume pedal Jr models 6180 and 6181, as well as the MVP.
Neye ihtiyacın var
Insert the loop of the short cord through eyelet from the rear of the pedal Pass cord down and under rear black pulley, and attach spring to loop.
Place the cord inside the pedal, under the main cross shaft, and let it lie there for now.
Move the pedal to the “toe-up” position.
Insert the loop of the long cord through the rear side of eyelet toward the front of the pedal.
From the front of the open pedal, gently pull the spring forward while pressing firmly on the rear of top plate. Continue to do so until it bottoms out.
Continue pulling the spring forward, and turn brass pot pulley to full counter-clockwise position. This correctly seats the pot and cord.
Bir başkası bu kılavuzu tamamladı.
