Giriş
If the device's screen has distorted images, or is blank and the troubleshooting guides don't seem to fix it, or if the device's screen is cracked, this guide will explain how to replace it.
Neye ihtiyacın var
Inser the flat end of a spudger into one of the two notches and pry off the case.
Remove the four 9mm Phillips #1 screws from the bottom of the radar.
Remove the bottom case.
Push the two black tabs down to release the ribbon attached to the display.
The display ribbon should now easily slip out from under the white strip.
2 farklı kişi bu kılavuzu tamamladı.
12 Yorum
Kelsey, Where do you get the part? I need a replacement screen for my Passport Max FB30947A3. Escort customer service won’t sell it to me and requires me to send the unit to them for a bog fee.
I need a display screen for a max 2
Where can a replacement screen be ordered?
Escort Max II screens are now available in ebay
John -
