Ana içeriğe geç
Escort Passport Max2 Display Replacement
Neye ihtiyacın var
  1. Escort Passport Max2 Display Replacement, Exterior Case: adım 1, 2 resimden 1. Escort Passport Max2 Display Replacement, Exterior Case: adım 1, 2 resimden 2.
    • Inser the flat end of a spudger into one of the two notches and pry off the case.
  2. Escort Passport Max2 Display Replacement: adım 2, 2 resimden 1. Escort Passport Max2 Display Replacement: adım 2, 2 resimden 2.
    • Slide the spudger around the perimeter of the radar housing until the case separates.
  3. Escort Passport Max2 Display Replacement: adım 3, 2 resimden 1. Escort Passport Max2 Display Replacement: adım 3, 2 resimden 2.
    • Repeat these steps to remove the other side.
  4. Escort Passport Max2 Display Replacement, Lens: adım 4, 2 resimden 1. Escort Passport Max2 Display Replacement, Lens: adım 4, 2 resimden 2.
    • Remove the four 9mm Phillips #1 screws from the bottom of the radar.
    • Remove the bottom case.
  5. Escort Passport Max2 Display Replacement: adım 5, 1 resimden 1.
    • Gently spread apart the thin silver frame that wraps around the device and remove the dark purple lens.
    • The silver frame can easily pop off of the device now that the bottom metal case has been removed. Don't worry if it comes off all the way. It can easily be put back in it's place.
  6. Escort Passport Max2 Display Replacement, Display: adım 6, 2 resimden 1. Escort Passport Max2 Display Replacement, Display: adım 6, 2 resimden 2.
    • Push the two black tabs down to release the ribbon attached to the display.
    • The display ribbon should now easily slip out from under the white strip.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Kelsey Ferrenberg
731 İtibar
4 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G1, Liner Spring 2018 UW Tacoma, Team S1-G1, Liner Spring 2018 üyesi
UWT-LINER-S18S1G1
5 Üyeler
12 Yorum
Kelsey, Where do you get the part? I need a replacement screen for my Passport Max FB30947A3. Escort customer service won’t sell it to me and requires me to send the unit to them for a bog fee.
Doug Denny - Yanıt
I also need to replace my screen and would like to know where I can get the part. Mine was dropped and the screen cracked. I do not feel like spending $139 to repair an older detector. Thanks for any info you can provide!
Aaron k - Yanıt
I need a display screen for a max 2
Jeff Dowdy - Yanıt
Where can a replacement screen be ordered?
Mike Rumble - Yanıt
Escort Max II screens are now available in ebay
John -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 35
Her zaman: 2,946
