Giriş
If you no longer hear sound from your Escort Passport Max2, and none of the troubleshooting guides seem to help, it may be that your Passport Max2's speaker is damaged. This guide will show you how to replace it.
Neye ihtiyacın var
Inser the flat end of a spudger into one of the two notches and pry off the case.
Remove the four 9mm Phillips #1 screws from the bottom of the radar.
Remove the bottom case.
Use the plastic opening tool to unplug the white connector from the motherboard.
Remove the motherboard.
Bir başkası bu kılavuzu tamamladı.
2Kılavuz Yorumları
Do you have a link to the replacement speaker part
I found the speaker on Amazon. It’s called “uxcell 2W 8 Ohm DIY Speaker Replacement Loudspeaker 20mmx40mm 2pcs”. I just put it in yesterday and it works like a charm! The only note is that you will need to remove the leads from the old, faulty speaker and solder them at the 2 contact points on the new speaker. This is MUCH easier than it sounds and takes only seconds. Either you will need a soldering gun (any cheap one will do) or have someone do it. This is the only part that was new to me. This may be of value to include in the above instructions, but they are otherwise excellent.
