Giriş
Use this guide to replace the vibrator in your Essential Phone. The vibrator is responsible for the haptic feedback when using the device.
Note: As of June 2019, there is no known replacement vibrator on the market.
Neye ihtiyacın var
If possible, drain the battery before disassembly. When the battery is charged, there's increased risk of a dangerous thermal event if the battery is overheated or damaged during repairs.
Heat the perimeter of the display to soften the adhesive securing it.
If available, use a hot plate or heat pad. Place the Essential Phone face-down and heat it to 85° C for at least 15 minutes.
Otherwise, use a heat gun to evenly heat the entire perimeter of the display until it's too hot to touch. Try to maintain a high temperature for 15-20 minutes—but beware that without exact control over the temperature, you can easily destroy the display.
Bu adımda kullanılan alet:Heavy-Duty Suction Cups (Pair)$14.95
While the phone is still hot, apply a heavy-duty suction cup to the top half of the display.
After positioning the suction cup, gently press down, and then close the handle to securely fasten the suction cup to the display surface.
Use the point of a spudger to pry the display cable pop connector straight up from its socket.
Use a Phillips #000 driver to remove the six 3.4mm screws holding on the back panel.
Remove the tape covering the loud speaker cable connector with a tweezer.
Use the flat end of a spudger to lift the tab of the loud speaker cable connector.
Using a tweezer, pull out the connector from the motherboard.
Use the Phillips #000 screwdriver to remove the five 2.4 mm screws holding down the motherboard.
Use the same screwdriver to remove the six 1.25 mm screws holding down connect clips onto the motherboard.
Remove the remaining 3.4 mm screw at the top of the motherboard with the same screwdriver.
Remove the two 1.25mm screws that hold on the vibrator cap using a Phillips #000 screwdriver.
