Ana içeriğe geç
Etekcity Lasergrip 1080 Button Replacement
Neye ihtiyacın var
  1. Etekcity Lasergrip 1080 Button Replacement, Battery: adım 1, 1 resimden 1.
    • Pull the battery cover away from the handle by gripping near the thumb groove.
  2. Etekcity Lasergrip 1080 Button Replacement: adım 2, 1 resimden 1.
    • Gently pull the battery out of the handle.
    • Excessive force could damage wires.
  3. Etekcity Lasergrip 1080 Button Replacement: adım 3, 2 resimden 1. Etekcity Lasergrip 1080 Button Replacement: adım 3, 2 resimden 2.
    • Disconnect the battery by pulling the connector away from it.
    • Positive first
    • Negative second
    • When replacing the battery, this order is reversed.
  4. Etekcity Lasergrip 1080 Button Replacement, Buttons: adım 4, 2 resimden 1. Etekcity Lasergrip 1080 Button Replacement, Buttons: adım 4, 2 resimden 2.
    • Remove the battery cover from the device by pulling it straight out.
  5. Etekcity Lasergrip 1080 Button Replacement: adım 5, 2 resimden 1. Etekcity Lasergrip 1080 Button Replacement: adım 5, 2 resimden 2.
    • Using the plastic opening tool remove the front and rear yellow covers.
    • When removing the back cover, be careful not to lose the buttons as they are not connected.
  6. Etekcity Lasergrip 1080 Button Replacement: adım 6, 1 resimden 1.
    • Remove the two 3.1 mm Phillips #0 screws.
  7. Etekcity Lasergrip 1080 Button Replacement: adım 7, 2 resimden 1. Etekcity Lasergrip 1080 Button Replacement: adım 7, 2 resimden 2.
    • Pull the two halves apart.
    • Be careful not to lose any components on the inside.
  8. Etekcity Lasergrip 1080 Button Replacement: adım 8, 1 resimden 1.
    • Realign the buttons with the button terminals.
    • Red terminal to red button.
    • Orange terminal to orange button.
    • Yellow terminal to yellow button.
Sonuç
Patrick Crawford
741 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 5-1, Blackwell Fall 2015 USF Tampa, Team 5-1, Blackwell Fall 2015 üyesi
USFT-BLACKWELL-F15S5G1
3 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 10
Her zaman: 459
