Ana içeriğe geç
Ethernet Port Replacement
Neye ihtiyacın var
    1. Ethernet Port Replacement, Linksys EA6900 Disassembly: adım 1, 3 resimden 1. Ethernet Port Replacement, Linksys EA6900 Disassembly: adım 1, 3 resimden 2. Ethernet Port Replacement, Linksys EA6900 Disassembly: adım 1, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Remove the antennas by unscrewing them from the base.
      • Flip over the device and locate the four rubber feet on the bottom.
      • Remove the rubber feet with tweezers
      FixBot'a Sor
      Yorum Ekle
    2. Ethernet Port Replacement: adım 2, 1 resimden 1.
      • Remove the 0.4cm head screws from each slot with the #1 Phillips head Screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. Ethernet Port Replacement: adım 3, 1 resimden 1.
      • Use a blue plastic opening tool to remove the top cover.
      • Move the blue plastic opening tool gently underneath the top cover from side to side.
      FixBot'a Sor
      Yorum Ekle
    4. Ethernet Port Replacement: adım 4, 3 resimden 1. Ethernet Port Replacement: adım 4, 3 resimden 2. Ethernet Port Replacement: adım 4, 3 resimden 3.
      • Gently lift the motherboard and remove it from the case
      • Put the motherboard over a (preferably white) surface.
      FixBot'a Sor
      Yorum Ekle
    1. Ethernet Port Replacement, Ethernet Ports: adım 5, 3 resimden 1. Ethernet Port Replacement, Ethernet Ports: adım 5, 3 resimden 2. Ethernet Port Replacement, Ethernet Ports: adım 5, 3 resimden 3.
      • Locate the Ethernet ports
      • Flip the motherboard and locate the 40 solder points corresponding to the Ethernet ports
      • Melt the 40 solder points using a soldering gun.
      • Wait between five and seven minutes for the ports to cool down.
      FixBot'a Sor
      Yorum Ekle
    2. Ethernet Port Replacement: adım 6, 1 resimden 1.
      • Hold the motherboard down and use the spudger to remove the Ethernet Ports.
      FixBot'a Sor
      Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Denis
611 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 11-1, Blackwell Fall 2016 USF Tampa, Team 11-1, Blackwell Fall 2016 üyesi
USFT-BLACKWELL-F16S11G1
4 Üyeler
12 adet Kılavuz yazıldı
1Rehber Yorum
Can you make a guide to replace the antenna base connector, mine get broken at the base, I wonder if it is possible to make the cable connection directly to the antenna, does that could work?
Enrique Jendrix - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 20
Son 30 gün: 73
Her zaman: 8,779
