Ana içeriğe geç
Ethernet Port Replacement
Neye ihtiyacın var
  1. Ethernet Port Replacement, Linksys EA6900 Disassembly: adım 1, 3 resimden 1. Ethernet Port Replacement, Linksys EA6900 Disassembly: adım 1, 3 resimden 2. Ethernet Port Replacement, Linksys EA6900 Disassembly: adım 1, 3 resimden 3.
    • Remove the antennas by unscrewing them from the base.
    • Flip over the device and locate the four rubber feet on the bottom.
    • Remove the rubber feet with tweezers
  2. Ethernet Port Replacement: adım 2, 1 resimden 1.
    • Remove the 0.4cm head screws from each slot with the #1 Phillips head Screwdriver.
  3. Ethernet Port Replacement: adım 3, 1 resimden 1.
    • Use a blue plastic opening tool to remove the top cover.
    • Move the blue plastic opening tool gently underneath the top cover from side to side.
  4. Ethernet Port Replacement: adım 4, 3 resimden 1. Ethernet Port Replacement: adım 4, 3 resimden 2. Ethernet Port Replacement: adım 4, 3 resimden 3.
    • Gently lift the motherboard and remove it from the case
    • Put the motherboard over a (preferably white) surface.
  5. Ethernet Port Replacement, Ethernet Ports: adım 5, 3 resimden 1. Ethernet Port Replacement, Ethernet Ports: adım 5, 3 resimden 2. Ethernet Port Replacement, Ethernet Ports: adım 5, 3 resimden 3.
    • Locate the Ethernet ports
    • Flip the motherboard and locate the 40 solder points corresponding to the Ethernet ports
    • Melt the 40 solder points using a soldering gun.
    • Wait between five and seven minutes for the ports to cool down.
  6. Ethernet Port Replacement: adım 6, 1 resimden 1.
    • Hold the motherboard down and use the spudger to remove the Ethernet Ports.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Denis
584 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 11-1, Blackwell Fall 2016 USF Tampa, Team 11-1, Blackwell Fall 2016 üyesi
USFT-BLACKWELL-F16S11G1
4 Üyeler
12 adet Kılavuz yazıldı
Bir Yorum
Can you make a guide to replace the antenna base connector, mine get broken at the base, I wonder if it is possible to make the cable connection directly to the antenna, does that could work?
Enrique Jendrix - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 21
Son 30 gün: 89
Her zaman: 7,032
