Ana içeriğe geç
Eton FRX3 Rechargeable Battery Pack Replacement
  1. Eton FRX3 Rechargeable Battery Pack Replacement, Rechargeable Battery Pack: adım 1, 1 resimden 1.
    • Pull the plastic tab on the battery compartment cover panel to loosen it, then pull the panel off.
  2. Eton FRX3 Rechargeable Battery Pack Replacement: adım 2, 1 resimden 1.
    • Disconnect the battery pack wires from the device and remove the battery pack.
Sonuç
To reassemble your device, follow these instructions in the reverse order.
3 farklı kişi bu kılavuzu tamamladı.
Kenneth Sills
762 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-6, Nance Spring 2016 USF Tampa, Team 1-6, Nance Spring 2016 üyesi
USFT-NANCE-S16S1G6
4 Üyeler
13 adet Kılavuz yazıldı
4 Yorum
My question is where can you find an FRX3 replacement battery?
jalwitt - Yanıt
Hey mate, you can buy the battery packs from a number of sources. Here's the link to one of those sources https://www.amazon.com/HQRP-FR200-BAT-3A...
james -
is it ok to replace it with a higher capacity lithium battery?
troydeleon - Yanıt
As long as the specifications match, that should be fine. Just be careful when swapping out components in circuits, as it can potentially destroy the device if they're incompatible!
Kenneth Sills -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 32
Her zaman: 5,287
