Ana içeriğe geç
Eureka 1660SP Pole Extender Button Spring Replacement
Neye ihtiyacın var
  1. Eureka 1660SP Pole Extender Button Spring Replacement, Motor Housing: adım 1, 2 resimden 1. Eureka 1660SP Pole Extender Button Spring Replacement, Motor Housing: adım 1, 2 resimden 2.
    • Before you start, make sure your vacuum is unplugged the power outlet.
    • Press and hold down the black button below the handle while pulling the pole out.
  2. Eureka 1660SP Pole Extender Button Spring Replacement: adım 2, 2 resimden 1. Eureka 1660SP Pole Extender Button Spring Replacement: adım 2, 2 resimden 2.
    • Press the black separator switch to separate the top and bottom halves of the vacuum.
  3. Eureka 1660SP Pole Extender Button Spring Replacement: adım 3, 3 resimden 1. Eureka 1660SP Pole Extender Button Spring Replacement: adım 3, 3 resimden 2. Eureka 1660SP Pole Extender Button Spring Replacement: adım 3, 3 resimden 3.
    • Use a #2 Phillips head screwdriver to remove six 13.9mm screws from the side of the motor housing (top half) as shown.
    • Remove two 14.1mm screws from the front face of the housing. You are now all set to open the housing.
    • Keep a watchful eye on the two screws from the front face. These two have additional collars to their necks and will not fit in any of the other holes, yet no other screw will fit in their spots without the collar.
  4. Eureka 1660SP Pole Extender Button Spring Replacement, Pole Extender Button Spring: adım 4, 1 resimden 1.
    • Pull out the button and the spring attached to it.
    • Swap the old spring with a new one.
  5. Eureka 1660SP Pole Extender Button Spring Replacement: adım 5, 1 resimden 1.
    • Insert the new spring and button back into the right slot as shown in the picture.
Sonuç
Nikhila Vijaybhaskar
242 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-1, Gulbrandsen Fall 2013 UMass Dartmouth, Team 1-1, Gulbrandsen Fall 2013 üyesi
UMASSD-GULBRANDSEN-F13S1G1
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 302
