Ana içeriğe geç
Eureka 1660SP Roller Replacement
Neye ihtiyacın var
  1. Eureka 1660SP Roller Replacement, Roller: adım 1, 2 resimden 1. Eureka 1660SP Roller Replacement, Roller: adım 1, 2 resimden 2.
    • Press the black separator switch and lightly pull the bottom half away from the top.
  2. Eureka 1660SP Roller Replacement: adım 2, 2 resimden 1. Eureka 1660SP Roller Replacement: adım 2, 2 resimden 2.
    • Remove the vacuum head from the lower half of the body.
  3. Eureka 1660SP Roller Replacement: adım 3, 3 resimden 1. Eureka 1660SP Roller Replacement: adım 3, 3 resimden 2. Eureka 1660SP Roller Replacement: adım 3, 3 resimden 3.
    • Turn the vacuum head wheels up and remove all seven 13.9mm screws from the bottom using a #2 Phillips head screwdriver.
    • Separate the top and bottom of the vacuum head. Set the top aside.
  4. Eureka 1660SP Roller Replacement: adım 4, 2 resimden 1. Eureka 1660SP Roller Replacement: adım 4, 2 resimden 2.
    • Turn the vacuum head's bottom over so that the inside of the head is facing up.
    • Using a Phillips #00 screwdriver, press down on metal bar of the roller on one side until it releases from the housing.
    • Turn the vacuum head's bottom over and pull at the roller and bar until they are completely out of the housing.
  5. Eureka 1660SP Roller Replacement: adım 5, 1 resimden 1.
    • Press the new bar and roller into place.
    • Replace the screws.
Bitiş Çizgisi
Jennifer Sheils
4 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-1, Gulbrandsen Fall 2013 UMass Dartmouth, Team 1-1, Gulbrandsen Fall 2013 üyesi
UMASSD-GULBRANDSEN-F13S1G1
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 12
Her zaman: 445
