Ana içeriğe geç
Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement
Neye ihtiyacın var
  1. Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement, Brush roll: adım 1, 1 resimden 1.
    • Unplug the vacuum from the outlet.
  2. Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement: adım 2, 1 resimden 1.
    • Use a damp paper towel to clean the bottom of the vacuum of any debris.
  3. Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement: adım 3, 2 resimden 1. Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement: adım 3, 2 resimden 2.
    • Flip the vacuum over so the bottom is facing up.
    • Use a Phillips #2 screwdriver to remove the four 3.0 mm screws.
    • Use a Phillips #2 screwdriver to remove the two 4.2 mm screws.
  4. Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement: adım 4, 1 resimden 1.
    • Pull the bottom and top cover of the brush roll compartment apart.
    • Internal components of the vacuum may fall out during this step, so keep track of where they are located for reassembly.
  5. Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement: adım 5, 3 resimden 1. Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement: adım 5, 3 resimden 2. Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement: adım 5, 3 resimden 3.
    • Lift the brush roll out of the vacuum.
    • The brush roll is connected to two white placeholders on both left and right sides. To remove these, pull them away from the brush roll.
  6. Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement: adım 6, 1 resimden 1.
    • Thoroughly clean the inside of the vacuum with a damp paper towel and let it dry.
  7. Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement: adım 7, 2 resimden 1. Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement: adım 7, 2 resimden 2.
    • To replace the brush roll, attach the two white placeholders on both ends of the brush roll and set them into the corresponding slots.
    • The slots are located on the left and right ends of the bottom cover.
  8. Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement: adım 8, 2 resimden 1. Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement: adım 8, 2 resimden 2.
    • Reattach the cover and screw it back into place using a Phillips #2 screwdriver.
    • The two 4.2 mm Phillips #2 screws go in the two middle bottom holes.
    • The four 3.0 mm Phillips #2 screws go in the side holes.
Sonuç
Plug in your device and test it to ensure that you have reassembled it correctly.
Mark Parala
157 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 39
Her zaman: 1,167
